Arscon
Hi, i have new nu audio evga, not pro. So i installed all and working good, driver ver 0.2.1.1.4. I connect heaphones with microphone + speakers 2.0 When i played in game i have couple freeze sound. Freeze 1 sec and sound back. What is going on ? I reinstall drivers evga. I only have evga drivers. So what i can do more? I have this in cs go. Sound disappears a second and back. I have this on headphones( i test in other computer and dont have any freeze)
- Ribbons : 270
Re: nu audio problem
2021/08/18 17:05:22
What sample rate and bit depth are you using. Similar complaints have been common at high sample rates and bit depths. If you aren't using 44.1 or 48 kHz sample rate and 16-bit bit depth, try 44.1 or 48 kHz sample rate and 16-bit bit depth and see if the problem goes away.
Arscon
2021/08/18 23:58:12
ty_ger07 What sample rate and bit depth are you using. Similar complaints have been common at high sample rates and bit depths. If you aren't using 44.1 or 48 kHz sample rate and 16-bit bit depth, try 44.1 or 48 kHz sample rate and 16-bit bit depth and see if the problem goes away.
I choose in nu audio program 44.1 16 bit and further the same. I also make off c-state in bios and the same. My sound is off for one second in game
post edited by Arscon - 2021/08/19 16:09:51
EVGA_Lee
Moderator
- Ribbons : 14
2021/08/20 17:44:36
Any difference if you disable the speakers or the headphones in the NU Audio software? What happens if you turn off the Nahimic software? Does this occur in any other game? What kind of motherboard do you have? If AMD, have you checked to see if you have the latest BIOS installed?
Arscon
2021/08/20 17:48:39
EVGATech_LeeM Any difference if you disable the speakers or the headphones in the NU Audio software? What happens if you turn off the Nahimic software? Does this occur in any other game? What kind of motherboard do you have? If AMD, have you checked to see if you have the latest BIOS installed?
Nope, its the same. So, right now all reinstall and windows. I only change to 24bit 44.1. I dont try off nahimic software when i played. My mobo is evga z490 dark kngpn, gpu rtx 3090 kngpn. I have 1.09 bios.
EVGA_Lee
Moderator
- Ribbons : 14
2021/08/20 18:16:08
Try setting the Nahimic options to off while you're playing. I want to see if VAC might be causing issues with the audio. Do you notice the audio skipping in any other applications, such as watching youtube or audio applications?
Arscon
2021/08/20 18:23:52
EVGATech_LeeM Try setting the Nahimic options to off while you're playing. I want to see if VAC might be causing issues with the audio. Do you notice the audio skipping in any other applications, such as watching youtube or audio applications?
Nahimic you mean evga soft where i can change something yes? Right now only in cs go i have this. I not tested in another games. I have new pc a couple days
EVGA_Lee
Moderator
- Ribbons : 14
2021/08/20 18:38:48
The Nahimic portions are the Surround, Reverb, and Compressor on the lower left side. Also the volume options on the lower right side, as well.
Arscon
2021/08/21 01:31:06
EVGATech_LeeM The Nahimic portions are the Surround, Reverb, and Compressor on the lower left side. Also the volume options on the lower right side, as well.
I have all nahimic portions off od the left side and right side. I only change in evga bit to 44.1 24-bit
Arscon
2021/08/21 15:06:35
so i tested, i make reinstall everything. I install clean windows and i have the same. My sound stoped for one second.
- Ribbons : 270
2021/08/21 19:55:13
Arscon
2021/08/22 01:21:32
ty_ger07 What about 16-bit?
I can trt 16-bit but when i choose 16-bit 44.1 i hear humming in headphones in cs go
Hoggle
2021/08/22 02:45:03
It might be good to have a list of games you have tried and a list of the hardware you are using. Only issue I have ever had was fixed by lowering the bit rate in mostly older games.
Arscon
2021/08/22 03:14:38
Hoggle It might be good to have a list of games you have tried and a list of the hardware you are using. Only issue I have ever had was fixed by lowering the bit rate in mostly older games.
so can you tell me what bit and hz you recomended to older games? What issue you have in games if you have greater bit rate? Thank you men
post edited by Arscon - 2021/08/22 03:21:01
- Ribbons : 270
2021/08/22 07:57:57
Arscon
That's a good sign, right? I mean, at least you hear something. I recommended it 3 days ago. Try 44.1 kHz 16-bit. Other than the humming problem, are there any other problems? Other than the humming problem, can you hear the other sounds which you weren't able to hear before? The humming is a different problem. First solve the problem of hearing sounds, then we can work on the humming second.
post edited by ty_ger07 - 2021/08/22 09:14:36
Arscon
2021/08/22 09:18:28
Arscon
so i try right now 44.1 16-bit
Arscon
2021/08/22 10:11:42
Arscon
so i tested right now 44.1 16-bit and is the same... I played, i have sound and everything and i get off sound for one second. This is sad... I spend a lot of cash for pc and i have problems. I will be grateful if someone help me with that problem.
Arscon
2021/08/28 14:04:30
Arscon
so, i unconnect my headphones from nu audio and connect to motherboard and i play 2 days and 0 problem. So i sure is problem with my nu audio. But i dont know its software problem or some problem with card and i need make rma? So what you guy recomended? If i no fix this problem i must unplugged this card becaouse its very annoying. Maybe someone help me?
