noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan
nstgc
2020/02/18 19:21:32 (permalink)
I'm looking to get a new video and have my sights set on either a 1650 and 1660. For me, at this price point, both will work. I'm leaning towards a 1650 since by the time the warranty runs out I'll be itching for a new card anyways, however from what I've read it is loud. Would the 1660 super (either single or dual fan) be quieter?
Currently I'm using a 950 SCX 2.0 (or something). It may be that I'm over thinking this and those cards are all about as noisy (or quiet) as this one.
post edited by nstgc - 2020/02/18 19:23:58
6 Replies Related Threads
    GTXJackBauer
    • Ribbons : 48
    Re: noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan 2020/02/18 20:05:23 (permalink)
    nstgc
    No matter what you chose, stick with a dual fan.  They'll should run cooler and quieter than a single fan but that will all depend on your environment.
    LMD3DNZM9LGK8GJ
    Gholman
    Re: noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan 2021/04/17 15:05:16 (permalink)
    I have a single fan 1650 super and it's a little noisy when I oc.
    Gholman
    Re: noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan 2021/04/20 01:53:46 (permalink)
    I'm enjoying my 1650super.
    It is a little noisy when overclocked to max.
    I was wanting 1660ti, the 1650 showed up first.
    And it was a huge upgrade over the onboard graphics.
    playing the waiting game to get a new card now.
    NSpecter
    Re: noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan 2021/04/28 12:41:15 (permalink)
    Hi nstgc!
    I am currently using a 1660 Dual Fan in my media PC setup. Even though I am using a tiny case (Jonsbo c2) I can barely hear the fans at all even when the GPU is at 100%. If I had a choice, I'd go with 1660 for sure. I think you'll enjoy that performance increase as well ;)
    Cheers!
     Want to Save up to 10% on your next EVGA purchase? Please consider using my Associate Code: RTS2LBUD959160C
    post edited by NSpecter - 2021/04/28 12:42:54
    Armons account
    Re: noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan 2021/04/28 15:22:59 (permalink)
    Always stick with a dual fan or tri fan GPU as they will be quieter, have better temps, look nicer, and generally last longer.
    Rig specs #1: Rtx 3070 FE (on air), 5900x, 64gb crucial ballistix 3600mhz CL16 RGB Ram,  addlink 2tb nvme ssd, WD SN750 1tb nvme ssd, bitspower water cooling parts for cpu (tubing, block, rad, distro plate), ASUS B550 XE, corsair RM850x, Lian Li o11 dynamic
    Rig specs #2: EVGA GTX 970 SC (on air), 9700k, 32gb crucial ballistix 3200mhz CL16 RGB Ram, Seagate 2TB HDD, OCZ vertex 4 128gb SATA SSD, lian li Galahad 240mm AIO (For CPU), gigabyte Z390 M Gaming, corsair cx650M, Corsair "big boy case" Carbide Series Air 540
    Rig specs #3: 2x XFX Radeon HD 7870 ghost (on air in cross fire mode), Some AMD FX 8 core CPU, 32gb Gskill 1600mhz CL9 RAM, Inland 128gb SATA SSD, some old corsair AM3+ 240mm AIO (for CPU), ASUS Crosshair V Formula-Z, An old Coolermaster 1200watt 80+ Gold rated PSU, Phanteks Eclipse (PH-EC300PTG_BK)
    zuberch
    Re: noise: 1650 Super vs 1660 Super single fan vs 1660 dual fan 2021/04/28 16:23:08 (permalink)
    if anything, undervolt it. get lower temps and lower noise
