mouse movement noise in audio
HighNoteJazz
2021/06/06 12:03:31 (permalink)
It doesn't happen all the time but especially during game play when my system heats up... I'm wondering if i need to replace my power supply or need an audio card. It's a cyberpowerpc so it wouldn't surprise me if it's a ghost i'll never find but any help would be great.
3 Replies Related Threads
    • Ribbons : 270
    Re: mouse movement noise in audio 2021/06/06 12:56:40 (permalink)
    Is "Spread Spectrum" an option somewhere in your motherboard's BIOS?  If so, is it disabled?  If it is disabled, enable Spread Spectrum.  That often helps.
    Others report that disabling Spread Spectrum helps, but I can't figure out why.
    Another thing to try is plugging and unplugging your mouse and headphones/speakers a few times to try to scrape off any oxidation which may have occurred on the metal of their electrical connections.  Doing so can fix issues with grounding.
    You can also try plugging your mouse and headphones/speakers into different ports, if available.
    post edited by ty_ger07 - 2021/06/06 13:21:38
    minimal00
    Re: mouse movement noise in audio 2021/06/08 07:25:38 (permalink)
    thanks
    • Ribbons : 270
    Re: mouse movement noise in audio 2021/06/11 21:44:25 (permalink)
    Any update?
