little help for temp using 280 clc
johnroque8
2019/01/02 10:23:19 (permalink)
Good day!
I'm not quite sure about if I install the evga 280clc correctly because I'm having 37deg idle and 58deg playing games temp of my 8700k (auto at cpu ratio, not OC).
TIA!
3 Replies Related Threads
    Re: little help for temp using 280 clc 2019/01/02 12:59:12 (permalink)
    Sounds ok to me.
    johnroque8
    Re: little help for temp using 280 clc 2019/01/02 20:31:36 (permalink)
    Ok bro tnx
    maxfly
    Re: little help for temp using 280 clc 2019/01/09 04:10:27 (permalink)
    you can always pull the block and see what kind of contact your making but like Sajin said, your temps are fine (without knowing the case and airflow at least).
    I7 8086K- MSI Z370 Gaming Pro Carbon AC-2x GTX 980 TI
    4x8GB HyperX Predator RGB DDR4 4000c19
    Samsung 500GB 960 EVO NVMe M.2
    WD Blue 1TB- EVGA SuperNOVA 1300 G2
    Thermaltake X71 Tempered Glass Edition Black
    UNDER CONSTRUCTION.
    EK Supremacy EVO Nickel- EK-FC980 GTX TI x2
    XSPC RX360- HWLabs SR2 420- HWLabs GTR 240
