hello every one
please help me
my problem:
my new evga rtx2080 ftw3 only supports 120hz refresh rate
however my monitor the benq zowie xl2735 supports 144hz
my old gtx970 runs @1440p and 144hz
but my new rtx2080 @1440p only runs at 120hz
when i set the monitor in the nvidia control panel to run at 144 hz
it flashes the screen and reverts back to 120hz hz every single time
i am aware that the specific model of monitor
will not display at 144hz while using audio
the bandwidth of the display port cable limits me to 120hz when i want to use audio on the monitor
how ever i use a sound card and run the monitor at 144hz with no sound being sent to it
i have reinstalled the drivers 3 times clean install every time
i have done all the windows up dates
i have done a full windows refresh "wipe the drive and start again"
when i use my 970 it works fine i can select 144hz
when i use my 2080 i will only go as high as 120hz
using display port cable
please help me very frustrating
is there a bios for the gpu that sorts this out
what do i do
are the display ports on the rtx2080 ftw3 all the same
i tried using different display ports nothing changed
thank you kindly
