hello power cable stuck
Nemisis25
2020/03/30 18:13:26 (permalink)
Hi, I seem to have a problem when trying to remove the 24 pin atx cable from the MSI h270 motherboard...It's almost feels like I am going to break the motherboard the way it flexes and refuses to let go. My powersupply is the EVGA 600 GQ model. Thanks for any suggestions.
4 Replies Related Threads
    sparetimepc
    • Ribbons : 27
    Re: hello power cable stuck 2020/03/30 18:33:13 (permalink)
    Nemisis25
    Don't know what else you can do but make sure you have the tab pressed in all the way before trying to pull it out, while pushing in the release tab try to wiggle it end to end when pulling on it, and at the same time pushing in on the board if you can.  that usually helps.
    Nemisis25
    Re: hello power cable stuck 2020/03/30 22:59:03 (permalink)
    Hi there, @sparetimepc. Thanks for your suggestion i'll give that a try the next time I decide to work on my pc! Just doing some PC spring cleaning before winter sets in!!
    • Ribbons : 84
    Re: hello power cable stuck 2020/04/01 06:12:48 (permalink)
    My suggestion is that you push the ATX cable in just slightly and then press the tab while trying to slowly remove it. Make sure the ATX cable is not in any type of skewed position.
    Nemisis25
    Re: hello power cable stuck 2020/04/01 17:23:48 (permalink)
    OK Thanks again, I will try that.
