Re: center channel and subwoofer output - and crossover
2020/03/04 06:47:24
I do not believe that there is any low pass filter on the center subwoofer channel coming from the card. Another user reported that there didn't appear to be.
Typically it is the job of the woofer to have a low pass filter appropriate for that woofer. (Different woofers have different frequency response ranges; and it would be kind of odd for EVGA to guess the appropriate low pass filter for your woofer.)
When you build your woofer, add a low pass filter inside of it, appropriate for the woofer speaker that you choose.
