Helpful Replyatx12v Power supplies - need help choosing
f70st
2021/01/13 12:38:50 (permalink)
Hi all,
This is my first post, so i hope you forgive me if im being a noob.
I recently got a Predator Orion 3000 PO3-620 pre-built pc. Everything works fine, but i noticed that the psu sparks when i turn the pc on via the wall socket, firstly, is the psu sparking ONLY when turning on the switch at the wall normal? once booted into windows, running games, watching movies, the psu is fine - no sparks. the sparks only occur when i turn power on/off via the wall.
Even if this is normal, i dont feel entirely comfortable with a brand new psu sparking.. ive already contacted acer but they are not giving any feedback or replies, so i have taken matters into my own hand. I want to replace the PSU but problem is the motherboard does not support the standard 24 pin connectors found on most psu's. Does EVGA provide any psu (650w gold 80+) that support atx12v?
I found the EVGA SuperNOVA 650 GT 650W which states it does support atx12v, but i wanted to make sure if there were any better alternatives. If you guys have any opinions please let me know, i am worried this faulty psu is going to fry my system :(
bob16314
  • Ribbons : 641
Re: atx12v Power supplies - need help choosing 2021/01/13 13:18:15 (permalink)
The PSU itself should not be sparking inside under any circumstances.
Buy an ATX standard power supply and put in it..But the problem is that the motherboard connector is Acer-proprietary (non-standard)..Soooo, you would need to use an adapter like this or this to convert a standard 24-pin ATX standard power supply to work with an Acer 12-pin motherboard..You can find those adapters at many places..All EVGA (and most all other) power supplies are ATX standard..You can use the OuterVision Power Supply Calculator to estimate the minimum recommended wattage PSU you need.
* Corsair Obsidian 450D Mid-Tower - Airflow Edition * ASUS ROG Maximus X Hero (Wi-Fi AC) * Intel i7-8700K (Delidded, TG Conductonaut) @ 5.4GHz* 16GB G.SKILL Trident Z 4133MHz * Crucial MX500 M.2 1TB * WD Black 500GB (x2) * Seasonic M12 II 750W * Corsair H115i Pro * EVGA GTX 760 SC * Dual-Boot Win7 Home 64-bit/Win10 Home 64-bit (20H1) *
f70st
Re: atx12v Power supplies - need help choosing 2021/01/14 05:53:32 (permalink)
Hi, thank you for your reply. I took another look at my motherboard and sadly i can only see a 6 pin connector, i dont see any 12 pin connectors. Ive looked on amazon and there are 24 to 6 pin adapters, www . amazon.co.uk/COMeap-Power-Adapter-Workstation-12-inch/dp/B06XW7RWNH/ref=sr_1_3?dchild=1&keywords=atx+24+pin+to+6+pin+adapter&qid=1610630724&sr=8-3
Ive also attached some pictures of the if you need a look imgur . com/a/43S870A
 Apologies for the spaces in the url, it seems as i am a new member evga wont allow me to post urls/links until i accumulate points
post edited by f70st - 2021/01/14 05:58:38
bob16314
  • Ribbons : 641
Re: atx12v Power supplies - need help choosing 2021/01/14 07:55:47 (permalink) ☄ Helpfulby f70st 2021/01/14 07:58:40
Well that sux that it's not your ordinary 24 to 12 pin Acer adapter, so I really don't know..Maybe Acer has a forum you can go to and find out.
f70st
Re: atx12v Power supplies - need help choosing 2021/01/14 07:58:49 (permalink)
yup if i knew that acer would exclusively be using proprietary components i would not have brought the pc. its a shame because everything else works fine, ive contacted acer and ordered a replacement psu, lets hope it goes well :D
thank you for all your help
aka_STEVE_b
EGC Admin
  • Ribbons : 56
Re: atx12v Power supplies - need help choosing 2021/01/14 10:43:17 (permalink)
I would for sure keep pressing ACER to take care of it , especially since I assume it is still under warranty. ?
..or at the very least ask the store where you bought it from.  & tell them Acer is not responding to you.
but looks like a new psu runs about $125 and up -  it uses some weird  ATX12VO
https://www.gamersnexus.net/guides/3568-intel-atx-12vo-spec-explained-what-manufacturers-think
https://community.acer.com/en/discussion/614184/can-i-upgrade-my-psu-on-my-acer-predator-orion-3000-p03-600
https://community.acer.com/en/discussion/558676/changing-psu-on-predator-orion-3000
https://community.acer.com/en/discussion/621167/acer-predator-orion-3000-psu-upgrade-wiring-help
https://community.acer.com/en/discussion/626123/acer-predator-orion-3000-po3-620-a-few-questions-psu-gpu-bios
post edited by aka_STEVE_b - 2021/01/14 10:58:42
AMD RYZEN 9 3900X  12-core cpu~ Gigabyte X570 Aorus Elite board ~ Nvidia RTX 3080 FE~ G.SKILL Trident Z NEO 16 GB DDR4 3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 Gig SSD ~ CORSAIR H80i v2 cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 31.5" monitor 1440 @ 144Hz ~ Win 10 x64
................ GET UP TO A 10% DISCOUNT ON PURCHASES BY CLICKING ....VVVVVVVVV.........
f70st
Re: atx12v Power supplies - need help choosing 2021/01/14 16:38:39 (permalink)
aka_STEVE_b
Sadly i dont have warranty anymore, ive contacted acer and ordered a replacement psu that is proprietary to their motherboard. I appreciate you input, the links you provided were very helpful, thank you :D
f70st
Re: atx12v Power supplies - need help choosing 2021/01/14 16:40:22 (permalink)
If the new psu has the same issues i might just buy a standard atx psu with 24 to 6 pin adapters
