freakdaddy64
- Ribbons : 5
not sure where to post this. i have the nzxt kracken x73 360mm cooler mounted top exhaust in a nzxt 710i case. im running 3 120mm nzxt aergb fans in front for intake and 1 140 rear exhaust. and using the nzxt cam software. my question is when im idle i see mid 40,s cpu temp and 26 to 28 liquid temps and undr load like when im gaming i see mid 50,s to 60 c cpu temp and up to 41 liquid temps so does that seem ok. im not seeing any over heating and ryzen master shows cpu 8 to 10 degrees cooler then the nzxt cam at idle and its my first aio so just looking for any opinions on my temps. thanks
asus rog strix b550 f gaming ryzen 7 5800x3d cpu gskill trident z neo rgb ddr4 3600 ram sabrent 2tb ssd m.2 storage sabrent 1tb boot asus rog 4080 oc corsair 5000d case evga supernova 1000 t2 psu nzxt x73 rgb 360 cooler asus rog xg349c 34 inch display asus rog xg27aqm 27 inch 1440p 270 hz monitor THE SMOOTH OPERATOR Associate Code: YLOPU45V2M8FQL9 Elite ID: 2RWCT4B87YQYR15NNQO
rsabatino
- Ribbons : 6
Re: aio cooling temps
2021/05/17 11:16:20
that's ok with today's CPUs 40 to around 50 are ok temps 60 also ok watch out for 90c or 100c. I go about the same I have a Phanteks CPU cooler glacier one 280 in my computer non-software controlled and I get about the same. I also tested with a stock cooler and I seeing temps in the mid-60s overclocked mid-90s. with AIO I get in the mid-70s overclocked. also, the ambient temps in the room the cooler your house the cooler the CPU and AIO can shave at least 10 to 20c off of the temps compared to stock cooling so today my CPU is 45c all that comes into play. I personally like using the motherboard over software from a program I was using the corsair AIO with ICUE and I was not getting the best cooling with the software cooler with overclocks. so that why I changed to using glacier one 280. the only way you can get lower temps is probably going custom loop cooling.
post edited by rsabatino - 2021/05/17 11:19:20
Operation System Microsoft Windows 11 Pro Processor AMD Ryzen 9 5950X 16-Core Processor Memory 24.2 GB Free (31.9 GB Total) Graphics Card NVIDIA GeForce RTX 3070 Ti (8.0 GB) Monitor HP 32 Display (1920 x 1080 @ 60 Hz) Disk Storage 5240.5 GB Free of 6542.2 GB Audio NVIDIA High Definition Audio Motherboard ASUSTeK COMPUTER INC. (ROG CROSSHAIR VIII HERO (WI-FI)) Mouse Razer BlackWidow V3 Tenkeyless Keyboard Razer Viper
freakdaddy64
- Ribbons : 5
2021/05/17 11:23:39
thanks for reply, i have the msi b450 tomahawk max mobo and it shows my pump fan and i could connect all fans to mobo and use mobo settings and i use msi afterburner for my osd while gaming. i like the nzxt software because it shows everything and controls everything i just got a bug with the nzxt osd not working while gaming but all is good.
rsabatino
- Ribbons : 6
2021/05/17 11:30:07
if you want more cooling just take off the front panel of your case if you can. I have seen videos on YouTube Gamers Nexus and he takes the front panels off of the pcs he tests and he shaves 10c off of the CPU temps
Starshine95
2021/05/17 11:36:01
That seems fine. You could use programs like HWiNFO64 or HWMonitor to check all the sensors and see if they give you the same values. You could also run some stress tests and see how the temperatures go. If you pass those you should be fine for any normal activity.
freakdaddy64
- Ribbons : 5
2021/05/17 11:38:02
i have thought about that because nzxt aergb fans airflow is through the back so for rgb to show in case they have to be exhaust and thought about drilling a bunch of holes in the front. why they make their fans that way when you cant see through the top or front ill never know.
rsabatino
- Ribbons : 6
2021/05/17 12:54:28
I would not drill holes in that beautiful case if you can just do this
Starshine95
2021/05/17 13:06:49
rsabatino I would not drill holes in that beautiful case if you can just do this
Either that, change the fans (maybe some Noctua fans) or just leave it as it is. There's no reason to drill holes in the case, those temperatures aren't bad and that solution seems extreme to me (and not sure it would help that much).
jakesaile
2021/05/17 13:32:03
I do pretty good at about 45 on my 1080 TI underload
Smiggie
2021/05/17 13:45:02
I5 10600k and corsair h100 here, I'm getting the same yours temperature!
freakdaddy64
- Ribbons : 5
2021/05/17 13:58:41
im not drilling holes in it,im good with temps especially since i dont overclock i only run stock.
- Ribbons : 115
2021/05/17 18:31:45
freakdaddy64
- Ribbons : 5
2021/05/17 21:17:02
Ariyu Grey
2021/05/18 09:35:01
I have a Corsair AIO with a 360mm radiator and the Ryzen 3800x usually stays at around 50C ° even under load
freakdaddy64
- Ribbons : 5
2021/05/18 09:41:04
is it mounted in top or front?
Ariyu Grey
2021/05/18 09:52:06
It is top mounted because front didn´t work in my case. the radiator would be lower than the cpu and that´s bad for the water pump and temps.
freakdaddy64
- Ribbons : 5
2021/05/18 10:06:48
i could go front but most info told me top and jay2cent said top was good cause it keeps liquid flowing evenly.
Ariyu Grey
2021/05/18 10:14:32
Yeah thats true, top is most of the time the better choice, cause air can´t get into the cooling circuit. If you want to mount it in the fron, than the pipes should come from the bottom of the radiator and the radiator should be above the cpu, cause air always goes to the highest point of the circuit.
Abbarsto
2021/06/06 13:08:33
Those sound like good temps to me, as long as your fan sound is tolerable.
freakdaddy64
- Ribbons : 5
2021/06/06 14:28:55
fan noise is good especially when your wearing headset lol but even without i run in performance mode and they not loud.
melfa3
2021/06/07 08:32:16
it depands on ur cpu as example amd 3900xt is very hot cpu if u maintain it in 60s c range ur oki
