Z390 FTW PC Randomly Freezes, CATERR Light Turns On When Freezing After Power Surge/Outage
dkracer
2023/06/02 00:45:09 (permalink)
Title basically explains it, had a power outage or surge a couple months ago (happened in the middle of the night so I'm not sure which), but since then it will randomly freeze and the CATERR light will turn on. For whatever reason it's only happened when I'm not stressing the system (mainly web browsing when it occurs). I go and play games or whatever like normal and its like nothing happened. It will also go like 2-3 weeks without it occurring then randomly it'll freeze.
Specs: All has been running fine up until the surge/outage, no overheating...etc
Mobo: Z390 FTW (Latest bios)
CPU: 9900k (stock clocks)
Ram: GSkill Trident Z 32GB
GPU: Asus Tuf 3080 OC w/ 1440P Gsync monitor
PSU: Corsair RM850x
SSD: Samsung 1tb nvme
2 Replies Related Threads
    Re: Z390 FTW PC Randomly Freezes, CATERR Light Turns On When Freezing After Power Surge/Ou 2023/06/02 01:08:05 (permalink)
    CPU, CPU IMC, or RAM issue is your most likely cause. I'd start off by testing the ram. If no errors are found on the ram then I would then disable all power saving states on the cpu, and retest for the issue. If after disabling the power saving states on the cpu doesn't resolve the issue then I would boost the voltages on the cpu vcore/imc to their max safe voltages while staying at stock clocks to see if that makes the issue go away. If raising the voltages on the cpu makes the issue go away then you'll know your cpu is the issue.
    MhzManiac
    • Ribbons : 8
    Re: Z390 FTW PC Randomly Freezes, CATERR Light Turns On When Freezing After Power Surge/Ou 2023/06/06 23:06:37 (permalink)
    If you don't have luck with what Sajin suggested, try reseating that ram.
    BTW: We have similar systems except I am running 5G on the CPU 24/7 for the last 4 months.
    post edited by MhzManiac - 2023/06/06 23:08:54
    That is me in the picture, anyone else ever pet a live Lion?
    EVGA Z390 FTW (Bios 1.08)  i9-9900KF 8 core, 32G Corsair Vengeance LPX Dual Chl 3000 XMP-1 ,
    Intel SSD6 M.2 2TB, Samsung 840 PRO 1TB / 512G SSD,   Gigabyte RTX 2080 Super , Win 11 Pro 64, EVGA Supernova 1300 watts, NZXT Phantom 820, Strix Raid DLX 7.1 surround, Corsair H100 Liquid , Dell S2417DG /S2409W / Acer XB241H Predator / Samsung C24F390 Curve/ Oculus Rift S VR
