Re: Z390 Dark case cable management clearance
2019/04/15 12:20:41
I'm not 100% sure, but if the R6 shares a similar layout to the S2, you should be okay. I currently have my Dark in a Define S2, I can take some photos when I'm home tonight.
You will have some issues with not being able to connect Front USB 2.0/3.0 header without an extension cable, and it will also be tricky to connect your front panel audio. I had to remove the rubber grommets to get my 24pin and 2x8pin eps cables through. Also, you'll have to route any needed SATA cables through the psu shroud cut outs and not the ones on the tray (almost completely blocked over the SATA area).
