Snypr18
- Ribbons : 282
Re: X99 Micro 2- Burned out mosfet, no system issues, what does it go to?
2018/12/22 16:55:29
Best to RMA. I wonder what the Bottom Side looks like?
post edited by bcavnaugh - 2018/12/22 17:00:11
Snypr18
2018/12/22 17:02:26
Thanks for the quick response. I understand this would qualify as a good reason to RMA, but if this wont cause any problems for me I would prefer to just continue using the board. That is why I am trying to identify the chip and what it goes to; if it isnt really going to limit my uses for the system (or will not cause further hardware failures) I am not too concerned. For example, if it is part of an audio input that I dont use. EDIT: I did not lift the board out of the PC but I did look underneath, as far as I could see the solder joints were intact and showed no signs of failure.
post edited by Snypr18 - 2018/12/22 17:05:50
- Ribbons : 282
2018/12/22 17:08:02
At least Open a Service Ticket This way it is on record before your Warranty runs out and is on Record with EVGA.
- Ribbons : 135
2018/12/22 18:01:19
Snypr18 Thanks for the quick response. I understand this would qualify as a good reason to RMA, but if this wont cause any problems for me I would prefer to just continue using the board. That is why I am trying to identify the chip and what it goes to; if it isnt really going to limit my uses for the system (or will not cause further hardware failures) I am not too concerned. For example, if it is part of an audio input that I dont use. EDIT: I did not lift the board out of the PC but I did look underneath, as far as I could see the solder joints were intact and showed no signs of failure.
I would not do that. Something caused that to fail and that is a lot of current. Also, I could not help but laugh at the designation screened on the board for that component. FU2
Chopper3200
2018/12/24 10:21:12
That component is a surface mount fuse. Something shorted out.
- Ribbons : 135
2018/12/25 15:12:04
Chopper3200 That component is a surface mount fuse. Something shorted out.
Yes indeed, Polytronics 2.6 amp resettable... well used to be before the magic smoke escaped.
- Ribbons : 270
2018/12/25 17:08:28
Not a MOSFET. It's a fuse. Probably for the USB Type-C port. Can you verify that the USB Type-C port no longer charges your phone or whatever you might have around to test? The data functionality of the Type-C port would likely still work, it's the charging functionality which would no longer work assuming that fuse is for that port. Perhaps the Type-C port IO Shield tab was improperly aligned and sticking into the top of the Type-C port. If everything you use the motherboard for is working properly, I don't think that I would RMA it. I have a feeling that EVGA would reject the RMA anyway and say that the damage was caused by improper use. I would guess that your motherboard warranty is now considered void.
post edited by ty_ger07 - 2018/12/26 00:15:42
Snypr18
2018/12/26 00:22:31
After some inspection I found a small black mark on the IO panel tab you have highlighted. It must have contacted an unshielded area of the Type-C port somewhere. At this point I think its safe to say this is what happened. In true EVGA fashion they have have offered to replace the board , but they do not have any X99 boards available. Debating whether I really want to drop cash on a new cpu rather than just continue using this board. I never use the Type-C port. I suppose I will continue using it over the holiday and see if any issues arise. Thanks to all for your input.
