Re: X99 Classified PWM Headers Max Watts/Channel
2018/04/26 12:13:30
You can run a nearly infinite number of PWM fans on one header, as long as the fans get their power and ground from the PSU instead of the header. To connect all the fans to one header, you will need a splitter anyway. Make sure the splitter you buy has a plug to provide power and ground directly from the power supply.
