Re: Would heat be a problem mounting the cards side by side?
2022/10/04 17:36:20
☼ Best Answerby Falita 2022/10/04 17:42:57
No, heat isn't really an issue with these cards. There are only a few components that get warm, and the heat on the backplates and shrouds is a good sign that heat is being transferred away from components. Overall, most of the components are rated for very high temperatures anyway, so as long as you get some airflow to the cards, you shouldn't have any issues.
