Worth upgrading my NU audio to NU audio pro?
AsimY
2020/01/05 16:13:06 (permalink)
Would i notice a huge difference with a sennheiser hd 599?
1 Reply Related Threads
    MSim
    • Ribbons : 38
    Re: Worth upgrading my NU audio to NU audio pro? 2020/01/06 21:22:24 (permalink)
    You won't notice a huge difference if you "upgraded" from NU Audio to NU  Audio Pro.  Both cards use the same DSP and DAC.
    Old NU Audio:
    OP-AMP (Headphone) - ADI OP275
    Capacitors - WIMA, Audio Note
    Supports Front Panel Header
    NU Audio Pro:
    OP-AMP (Headphone) - Linear Technology LT1469
    Capacitors - Audio Note Seiryu, Audio Note Standard, AVX F95 Audio, WIMA, Nichicon, Panasonic
    Supports the analog surround addon card
