Helpful ReplyHot!Wil a USB-C cable work with the XR1 Pro?
sirdanos8i
2022/03/27 17:32:37 (permalink)
The EVGA XR1 Pro comes with a USB-C cable breakout to USB3.0-A and USB2.0-A. I assume this is for additional power. I am wondering if a USB-C to USB-C cable could work when attached to a USBC port on a computer?
Hoggle
Re: Wil a USB-C cable work with the XR1 Pro? 2022/03/27 23:40:40 (permalink)
USB-C port work with a USB-C cable.
jumpymonky70
Re: Wil a USB-C cable work with the XR1 Pro? 2022/03/28 11:21:34 (permalink)
I actually am trying this now with a USB-C cable to my USB-C port and I can't capture over 720p? I don't have any more slots for USB-A I can really use. Any ideas?
itmatty
Re: Wil a USB-C cable work with the XR1 Pro? 2022/06/14 07:22:53 (permalink)
do both of the usb type a plugs need to be plugged into the computer?  I have just been plugging the 3.0 in.  The limited documentation that came with the capture card doesn't explain why there are two usb type a plugs
Hoggle
Re: Wil a USB-C cable work with the XR1 Pro? 2022/06/14 11:03:25 (permalink)
itmatty
If using the splitter cable to USB-A you would want to plug in both.
MonkeyZ
Re: Wil a USB-C cable work with the XR1 Pro? 2022/06/16 20:47:52 (permalink) ☄ Helpfulby Cool GTX 2023/09/25 08:36:27
I had the same issue where my stream in obs looked green and my series x resolution was limited to 720p.  I am using the Samsung G70A so i turned Adaptive Sync and LLR off.  I then set the monitor to 60 hz and at that point it was fine.  I could play in 4k w/HDR and stream in 720p.  I'll continue to play with it some more.
RaverX3X
Re: Wil a USB-C cable work with the XR1 Pro? 2022/06/16 22:19:15 (permalink) ☄ Helpfulby Cool GTX 2023/09/25 08:36:30
I have tested it with usb - c to usb -c gen 2/thunderbolt 3 works fine, which supports up to 10 gbps. You are fine with usb - c to usb -c cables
BaserinoGaming
Re: Wil a USB-C cable work with the XR1 Pro? 2023/09/25 04:57:00 (permalink)
İ have same issue green screen on obs and 720p on my g7 odysey 4k monitor . Can you tell me what should i do please ?
post edited by BaserinoGaming - 2023/09/25 05:01:27
