Hot!Who's going 1080Ti on water? Founder's + EK block or HydroCopper?
Page: 12345.. > >> Showing page 1 of 22
GTXMan
2017/03/07 11:29:04 (permalink)
I have until 24th to step-up from 1080 Hybrid. I figure my only option will be a Founder's, then I was planning on using the EK TXP block. I could also just keep the Founder's, use it as-is until the HydroCopper, then sell and put money towards it, but I guess not really worth it at that point as I assume the difference will be greater than just buying the EK block.
Just interested what other people who are planning on a water setup for this card are doing.
633 Replies Related Threads
    Xantac
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 11:48:27 (permalink)
    Well I grabbed the EK nickle block yesterday before they sold out everywhere, Wasn't paying attention and didn't order the Nickle backplate in time and its out off stock everywhere. So yea anyway, the reference ti with the ek block.
    • Rig 1: Rampage5/w 6850K g.skill 3200 cas15, High-speed PC HPTX Bench /w 1080Ti ftw3 + 2xRX580 @102 MH/s  Eth
    • Rig 2: 3930k RIVE /w Koolance mobo/cpu blocks/16gb 2133 c9, EVGA 1080 Ti Sli EK Nickel Blocks & a 1060 98MH/s Eth
    • Gamer PC=phenom II x925 +560 Ti
    • Acer Predator Monitor
    • 2 1070's incoming
    • Xantac's Heatware
    GTXMan
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 12:35:50 (permalink)
    Xantac
    Cool. I think I'm going with the Nickel/Acetal and I'm kind of digging their red back-plate. It's aggressive but red/black is my color scheme...
    EVGA GTX Hybrid
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 12:50:42 (permalink)
    EVGA 1080Ti FE with an EVGA AIO Hybrid Cooler.
    Had EVGA 1080 FE SLI, both running 45C max at 2050Mhz all day with those Hybrid Kits!
    i7 5930k | 1080 FE Hybrid + 1080 Ti FE| 24GB Vengeance DDR4
    x99A GAMING 7 | SuperNOVA 1300 G2 | H115i | DG-87
    PG348Q | Z213 | G900 | G910
    EVGA #1 for GPUs!
    Innovator_
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 12:53:24 (permalink)
    I might go with the FE and put a Hybrid, I can't wait until May for the FTW3 tbh.  I've never done anything to my GPU (running a 760) so any tips or advice would be recommended.
    • Ribbons : 77
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 13:13:51 (permalink)
    EK WB are Great on my Full Titan X pascals, so should work as well on 1080Ti
    Nibbler - EVGA X99 Classified, 5960X, 2-TitanX Pascl & EVGA 1080FE, Custom loop, modded Phanteks Enthoo Primo, 32GB GSkill DR4, Intel NVMe PCIe 750 SSD, Win10 Pro, EVGA 1600 P2, Folding 3.5M PPD, 4K Acer XB280HK monitor
    Bling AIO Folding Rampage5e10, 5930K, EVGA CLC 240 2-EVGA 1080Ti FTW3 Hybrid, 32GB GSkill DDR4, Samsumg 850 Pro SSD, Win 7 Pro 64bit, EVGA 1200 P2 PSU, Folding 2M PPD, Thermaltake View 71 Affiliate code 5MLLDCG6B
    Xantac
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 13:39:47 (permalink)
    I really,really like my nickle/plexi blocks for my 780 ti classies, I prefer EK blocks like I prefer my gpu's EVGA.
    • 2 1070's incoming
    • Xantac's Heatware
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 58
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 13:41:02 (permalink)
    I ordered two blocks from ek the moment they showed they would fit the 1080ti. Nickle plexi all the way.
    EVGA GTX Hybrid
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 14:27:54 (permalink)
    I'm sure it will the PCB is so close to the TITAN XP.
    EVGA #1 for GPUs!
    EtherealEye
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 14:34:11 (permalink)
    I might do the same but I fear I may get a silicon loser and regret the waterblock
    GTXMan
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 15:17:43 (permalink)
    Hybrid's a good way to go, too. Does the 1080 AIO fit the 1080Ti then?
    Innovator_
    Going to be a hell of an upgrade. First advice would be don't f*#% it up! Just kidding. I'm running a factory 1080 Hybrid so no tips from me, but I think as always you just want to be careful, take it slow, and do some research/watch some how-tos beforehand (for the 1080, for example) to get an idea of everything involved.
    Confirmed to work.
    • Ribbons : 77
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 15:32:54 (permalink)
    My comment was about how well the EK blocks keep my Titan X pascal cards cool
    Guess my original comment was clear as mud
    Counteragent
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 15:43:48 (permalink)
    whats the part number / link to the EK 1080 TI Waterblock?
    Motherboard    Asus Rampage V Extreme
    Processor    Inteli7-5960X Extreme Edition
    Memory    Dominator Platinum 32GB DDR4 DRAM 2800MHz
    Video Card # 1    EVGA GeForce GTX 980 Superclocked
    Video Card # 2    EVGA GeForce GTX 980 Superclocked
    Video Card # 3    EVGA GeForce GTX 980 Superclocked
    Hard Drive # 1    Samsung SSD 850 Pro 512Gb
    Hard Drive # 2    Samsung SSD 850 Pro 512Gb
    Hard Drive # 3    WD4003FZEX
    Hard Drive # 4    WD4003FZEX
    Hard Drive # 5    WD1000DHTZ
    Hard Drive # 6    WD1000DHTZ
    Power Supply    Corsair AX1200i Digital ATX Modular Power Supply
    mrkwhlr2
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 15:54:02 (permalink)
    I'm waiting on the Classified.
    Corsair Obsidian 800D |  EVGA Z170 Classified K | 2x EVGA 980 ti Classifieds w/modified EVGA Hydro Copper Classified Water Blocks in SLI | i7 6700K w/EK Supreme HF H20 block | 1x256gb Samsung EVO  | 1x500gb Samsung EVO | 4x4gb G.Skill DDR4 3200 16-16-16-35 | EVGA SuperNOVA 850 T2  | Fatal1ty X-Fi Sound | Asus ROG Swift 27" 165hz | r.i.p JH......
    • Ribbons : 125
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 15:54:18 (permalink)
    Removed for GTXJackBauer The Stalker of the Forums.
    post edited by bcavnaugh - 2017/05/11 21:14:40
    Innovator_
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/07 17:32:38 (permalink)
    GTXMan
    Innovator_
    I'd imagine there will be a hybrid kit later on.  Any performance upgrade like comparable to FTW if I OC?  Shouldn't overheat or have bad temps to where I can push the cards limit, no?  I've been looking at videos, it seems pretty simple.
    post edited by Innovator_ - 2017/03/07 17:37:32
    StealthArsenal
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:09:56 (permalink)
    Do we know if the FE backplate will mount up with the EK Nickel/Acetal block installed?  Wondering if I need the EK backplate or not.
    My Affiliate Code: PGAH4ZMWSG
    Main Rig:  |Intel Core i7 7820X||Aorous Z299 Ultra Gaming ||Asus Xonar DSX||Corsair Air 740||EVGA Supernova P2 1000||EVGA GTX 1080TI FTW3||Samsung 950 Pro 250gb NVME||Samsung Evo 500GB SSD x 2||Fractal Design Celcius S36||Logitech Z5500||Acer Predator XB271HU||Alienware AW34 Curved||16GB Crucial Ballistix Elite||EVGA Torq X10||Corsair K70||Cablemod PSU Cables (Green/Black)|
    • Ribbons : 125
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:12:46 (permalink)
    post edited by bcavnaugh - 2017/05/11 21:14:50
    StealthArsenal
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:21:40 (permalink)
    Guess you beat me too it.  I was looking through this thread to see what blocks everyone was using and looking on performance pcs for blocks and didn't realize you posted one.  Great minds think alike.
    the_Scarlet_one
    • Ribbons : 58
    StealthArsenal
    Usually rhe founds backplate doesnt because of the screw size that is utilized. I went ahead and grabbed the backplates that I needed to match the blocks while i was buying.
    -Wolfy-
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:28:02 (permalink)
    Could have sworn they said they were working on releasing the AIO Hybrid kits for the Titan X and the 1080 Ti FE on the PAX live stream eariler. I'm upgrading my 2 GTX 1070 FTW Hybrids and hate to lose the low temps. If they don't release it I guess I'm going to have to build a custom GPU loop.
    the_Scarlet_one
    • Ribbons : 58
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:33:13 (permalink)
    -Wolfy-
    Jacob did say they are working on a kit.
    -Wolfy-
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:35:51 (permalink)
    Scarlet-Tech
    -Wolfy-
    Well ok good enough reason to get the FE card.
    #23
    StealthArsenal
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:37:30 (permalink)
    Does the hybrid kits from the other cards cool as well as an ek setup?  I was planning to introduce my block to my EK Predator setup
    #24
    • Ribbons : 125
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:41:36 (permalink)
    post edited by bcavnaugh - 2017/05/11 21:15:04
    #25
    StealthArsenal
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 17:45:55 (permalink)
    Interesting.  But it just doesn't look as good unless they change the design.  But then, it has its own rad and wouldn't have to share with my 360.
    But in actuality, it won't fit in my Phanteks Evolv TG.  The 360 and fans block at least a quarter of the rear fan mount and the fittings up front would require a front mounted rad to be banging off my drive cages.
    post edited by StealthArsenal - 2017/03/10 17:47:58
    #26
    MemphisUFC
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 18:26:00 (permalink)
    Can i get a 100% for sure that a Hybrid Kit will be available for the 1080 Ti?  I'm Stepping Up and don't want to get stuck with a FE.  I love my current 1080 Hybrids both in performance and in looks.
    #27
    El-Dubya
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 20:36:52 (permalink)
    Hmmm, wonder when/if EK will release back plates that say "1080 Ti" instead of Titan X (would prefer they were just plain actually).
    #28
    the_Scarlet_one
    • Ribbons : 58
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 20:42:54 (permalink)
    El-Dubya
    I dont know if they will.. I am going to ignore the word titan, and just be happy without having to wait, lol.
    #29
    El-Dubya
    Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper? 2017/03/10 20:54:19 (permalink)
    Scarlet-Tech
    El-Dubya
    Well the Titan X(P) plexi/nickel blocks were unavoidable (need those naow! haha), but a back plate I think I can hold off on.....maybe
    #30
