the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper?
2017/03/10 20:58:05
El-Dubya Well the Titan X(P) plexi/nickel blocks were unavoidable (need those naow! haha), but a back plate I think I can hold off on.....maybe
I'm impatient.
bojerka
2017/03/10 21:55:50
CPU : INTEL Core i7-8700KGPU : EVGA GeForce GTX 1080 Ti SC2 Hydro Copper GAMINGRAM : G.SKILL TridentZ RGB Series 32GB DDR4 3200MHz 14-14-14-34BOARD : ASUS ROG Strix Z370-F GamingPSU : PHANTEKS Revolt X 80 PLUS PlatinumCase : Phanteks Enthoo EliteMonitor : 32" Samsung G75T Odyssey G7 240HzCPU block : Cuplex Kryos NEXT VARIO 1156/1155/1151/1150, PVD/.925 silverPump : D5 NextReservoir : HEATKILLER® Tube 200 D5Radiator : HardwareLabs Black Ice SR2 360MP + The Black Ice Nemesis 280GTS XFlowFittings : EK-HTC 12/16 mm - Black ChromeFans :&nbs
StealthArsenal
2017/03/11 04:26:04
@Scarlet-Tech, I agree with you. I will just ignore the Titan name on the backplate. If EVGA comes out with a cool plate for it, maybe I will switch. I don't want to look at a bare PCB. I went ahead and order the acetal/nickel plate with black backplate. Not running colors through my loop so I figured black would be best.
My Affiliate Code: PGAH4ZMWSG Main Rig: |Intel Core i7 7820X||Aorous Z299 Ultra Gaming ||Asus Xonar DSX||Corsair Air 740||EVGA Supernova P2 1000||EVGA RTX 2080TI Ultra FTW3||Samsung 950 Pro 250gb NVME||Samsung Evo 500GB SSD x 2||Fractal Design Celcius S36||Logitech Z5500||Acer Predator XB271HU||Alienware AW34 Curved||32GB Corsair Vengeance 3000 mHZ ||EVGA Torq X10||Corsair K70||Cablemod PSU Cables (Green/Black)|
Methodical2
2017/03/11 08:28:44
I was planning to go with the Hydro Copper card this go round. What is the difference between the Hydro Copper card and Reference card with water block, other than the Hydro comes with the water block already mounted? Thanks
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic" BlackECase: Caselab Magnum STH10 MB: Asus X670E Hero CPU: Ryzen 9 7950x (EK-Quantum Vector²) GPU: Asus 4090 TUF OC (EK-Quantum Vector²) Memory: G.Skill Trident Z5 Neo DDR5 (6000 @64gb) Storage: WD M.2 NVMe 2TB (OS), 2x4TB (Photography), 1TB (Games) Fan Controllers: Aquacomputer Aquaero 6 XT & Octo PSU: EVGA 1200 P2 Monitor: LG 48" UltraGear OLED 4k
the_Scarlet_one
- Ribbons : 79
2017/03/11 08:38:19
Methodical2 I was planning to go with the Hydro Copper card this go round. What is the difference between the Hydro Copper card and Reference card with water block, other than the Hydro comes with the water block already mounted? Thanks
Wait time.. blocks are ready now from 3rd party manufacturers. You have to install them, or have someone else install them for you. The hydrocopper blocks are generally thicker, and the inlet/outlet terminal is much thicker and wider.
Methodical2
2017/03/11 08:42:25
Scarlet-Tech
So no difference in performance, correct? So, I can buy the FE version now and just install the block myself without the wait time, correct? Thanks
the_Scarlet_one
- Ribbons : 79
2017/03/11 08:47:06
Methodical2
Maybe 2 or 3 degrees.. waterblocks are awesome these days, and there is a massive variety to choose from.
Methodical2
2017/03/11 08:49:57
Scarlet-Tech
Methodical2
Sorry, I wasn't quite clear. I meant there's no performance difference between the Hyrdo Copper and a FE watercooled card. I guess I will get in line with the rest of the crew for a FE card.
the_Scarlet_one
- Ribbons : 79
2017/03/11 08:51:39
The hydrcopper will be overclocked out of the box, but you can easily overclock the card yourself and make up for it.. then you dont have to wait 2 months for the Hydrocopper to hit the market :-)
- Ribbons : 282
2017/03/11 08:54:35
Removed for GTXJackBauer The Stalker of the Forums.
post edited by bcavnaugh - 2017/05/11 21:15:26
bojerka
2017/03/11 09:02:15
GTX 1080 Hydro Copper first time annouced in jun/july and real available in stores October (US). In my country end of November. Really bad release dates.
bjohannes1984
2017/03/11 09:18:23
Were the Hydro Copper 1080s binned in any way?
Intel i9-11900K - MSI MEG Z590 ACE - EVGA RTX 3090 K|NGP|N HYBRID - 32GB G.SKILL DDR4 3600MHz
ordained87
2017/03/11 09:27:33
Have my block and backplate on order. Performance pc's have a backorder on the backplates, however they sent me an email stating they will be getting their next shipment in this coming Monday. Ordered my stuff on the 9th to make sure I get a block. Went with the Acetal copper EK block. I wonder how far these 1080TI's will boost on their own with no thermal limit to affect them.
wanescotting
2017/03/11 09:48:36
Probably Hydro Copper, I don't mind waiting as I am in the process of closing on a house, so funds are presently tied up. However, if the hydro copper is not released or is just god ugly, I might go the FE + EK waterblock route
12700K - EK Monoblock Asus Maximus Z690 Hero G.SKILL Trident Z5 32gb DDR5 6400 4090 FE - EK Wb Intel 960gb 905p Intel 512gb 670p Solidigm P41 Plus Series 1TB Seasonic PRIME 1300W (cable mod 12vhpwr) Enthoo 719 - Custom Loop > Barrow Daridp-30 360 (DDC Pump Rad combo) > Swiftech 360 Rad > XSPC Crossflow 360 Rad > EK 360 FLT DDC Res Pump combo > Swiftech Helix Fans Push-Pull > Swiftech Hydrx coolant (custom mixed heavy) LG 55" CX Oled
the_Scarlet_one
- Ribbons : 79
2017/03/11 10:10:36
Hydro isnt ugly. Imthe 700 series hydros were plain, but functional. The 900 and 1000 series were both attractive.
- Ribbons : 282
2017/03/11 10:13:04
post edited by bcavnaugh - 2017/05/11 21:15:40
notfordman
- Ribbons : 28
2017/03/11 10:46:48
Scarlet-Tech Hydro isn't ugly. Imo the 700 series hydros were plain, but functional. The 900 and 1000 series were both attractive.
+1 They are made by EK the last few years. I will definitely have a block on mine, may have to save...but YES, it will be mine!
randpost1
2017/03/11 11:34:24
I picked up a used EVGA 1080 Hybrid kit on CL for 30$. I'm going to install it with all original shroud and components of the 1080ti FE with only the window, HS and piece that holds the window removed. I wont even have to take apart the entire card. Just the HS, window, and piece that holds the window. not my photo, but you get the picture with this Titan XP.
Muezick
2017/03/11 12:56:05
Probably just gonna sell my FE if it doesn't perform well and buy the inevitable FTW3 Hybrid that gets released. Hope I don't have to, I kinda wanna hang that FE shroud on my wall. And if it does perform well, then I'll buy a hydro copper plate and finally take the plunge into custom loops. lol.
MiguelEVGAfan
2017/03/11 13:32:21
randpost1 I picked up a used EVGA 1080 Hybrid kit on CL for 30$. I'm going to install it with all original shroud and components of the 1080ti FE with only the window, HS and piece that holds the window removed. I wont even have to take apart the entire card. Just the HS, window, and piece that holds the window. not my photo, but you get the picture with this Titan XP.
you think it will work with the ti
StealthArsenal
2017/03/11 14:33:47
Gamersnexus is currently mounting on to their TI. They have part one of the custom TI hybrid on their website and youtube. Looked like the blocked lined up fine on the pcb.
20184549615095
2017/03/15 23:09:21
So, will any titan wb fit the 1080ti fe or is it only certain titans? I just dropped over 2grand on my build and got the 1080hydrocopper 3 days before they announced the ti release!!! I dont mind using a used wb from a titan as long as it works since ill save a little money. I had already went 500 over budget on my build and the misses still won't look at me!!!! I'm having to tread lightly and saying im gonna spend another 200..... i may not be alive long after that!
ypsylon
2017/03/16 03:41:05
For Titan block compatibility on 1080Ti check on vendor website, contact support. Some are compatible (like EK or Watercool), some are not (like Bitspower or Phanteks). I don't know about EVGA Hydrocopper vel Switfech.
rodcpierce
2017/03/16 03:49:06
Im also in line for the step up program to the 1080ti FE. I have an EK block and back plate on order. Cant wait for the stuff to get here!
zswickliffe
2017/03/16 05:04:55
I'll be going on water. Probably pick up a used hybrid kit and make it work at first while I design my custom loop.
i7-4790k @ 4.6GHz 1080 Ti @ 2050MHz
337am
2017/03/16 06:33:20
Scarlet-Tech
Methodical2
I was told that my 980 hydrocopper block was made by EK. I couldn't remember if it was evga or EK that told me that. I ended up switching the hydrocopper block out for an EK to match my 2nd card. There was no temp difference.
337am
2017/03/16 06:34:51
I'm waiting on this one to be released.
meizme
2017/03/16 07:13:46
337am I'm waiting on this one to be released.
VERY NICE!
Operating System: - Windows 10 x64 Pro - Custom Lite Edition - Build 1703 Display: - LG 34UM95 21:9 ultrawide (3440*1440) CPU: - Intel Core I7-3770k @ 4.45Ghz 0.95v Motherboard: - Asus maximus V extreme Videocards: - [2x] EVGA GeForce GTX 1080 Ti FE Video Cards in SLI Memory: - G.SKILL TridentX Series 16GB DDR3 @2400Mhz Power Supply: - OCZ 1250w ZX PSU Cooling: - [3x] Akasa 140mm Viper PWM Fans (radiator) & [8x] ML140 140mm PWM Magnetic Levitation (Case) - Magicool Extreme Triple 140mm Radiator & Swiftech Apogee GTZ CPU Waterblock Drives: - [1x] HYPER M.2 X4 PCIe - 256Gb 950 Pro - [1x] 3Tb & [3x] 1Tb 7200rpm HDDs - [2x] 256Gb & [1x] 500Gb SSDs
bojerka
2017/03/16 08:27:12
TheWizardMan
2017/03/16 09:01:01
Came here to ask about this actually. Has anyone used, or read a review on, the Phanteks 1080 waterblocks?
| Asus Maximus IX Formula | Intel 6700K @ 4.8GHz | EVGA 1080 Ti w/ EKWB WBs (x2) | Phanteks Luxe TG | Custom Loop | | 32GB G.Skill Trident Z 3733 MHz | Samsung 960 EVO 500 GB M.2 Drive | Samsung 850 EVO 1 TB SSD | Cablemods Sleeved Cable Kit |
