Which pro sound card do I need
TMatzelle60
2020/01/01 20:07:51 (permalink)
I am running the audio engine a2+ with a audio engine s8 subwoofer which pro version should I get
3 Replies Related Threads
    • Ribbons : 270
    Re: Which pro sound card do I need 2020/01/02 09:31:13 (permalink)
    There is only one EVGA Nu Audio Pro sound card version.  It's the EVGA Nu Audio Pro.  What do you mean "which version"?  There is only one version.  The daughter card is an optional add-on.  It's not really a different version.  The daughter card adds 7.1 channel audio.  Without the daughter card, you get 2 channel audio.  Which one do you need?  I don't know... which one do you need?  Are you using 2 channel audio?  Or more than 2 channel audio?
    TMatzelle60
    Re: Which pro sound card do I need 2020/01/02 13:22:22 (permalink)
    Like I stated im using a AudioEngine A2+ speakers and a subwoofer by AudioEngine. So I assume that is a 2.1
    EVGA_Lee
    Moderator
    • Ribbons : 14
    Re: Which pro sound card do I need 2020/01/02 14:32:47 (permalink)
    Audioengine suggests that the Speakers and Sub can be connected within the same system, so the NU Audio Pro (712-P1-AN11-KR) should suffice:
    https://3zxsxd2tnlbj2tbfsk41nf0n-wpengine.netdna-ssl.com/wp-content/uploads/2016/12/S8-W3-Setup-Manual.pdf
