Patrick1986
RainStryke
The Advocate
- Ribbons : 60
Re: What kind of Power supply is best for 3090 ti?
2022/07/20 10:22:02
Main PC | Secondary PC Intel i9 10900K | Intel i7 9700KMSI MEG Z490 ACE | Gigabyte Aorus Z390 MasterASUS TUF RTX 3090 | NVIDIA RTX 2070 Super32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17SuperFlower Platinum SE 1200w | Seasonic X-1250Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GBCougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5 3DMark Results:Time Spy|Port Royal
Patrick1986
2022/07/20 10:35:18
2022/07/20 11:15:23
Easy - EVGA - Power Meter Advanced - OuterVision Power Supply Calculator Or just add up the Total watts of power for each part of your PC ... use a web search to find values Make Sure the PSU you buy has enough of the Connectors you need sometimes that means getting the next size larger IMO - PSU should be oversized by 20% of expected Max Watts needed So, if your OC CPU, GPU & other items = 1000W --> then get a 1200W PSU Yes, a 1000W load can work with a 1000W PSU but will it last for 5 to 10 years ? & what about future updates - seems the next gen GPUs are power hungry
Patrick1986
2022/07/20 12:45:19
Cool GTX Easy - EVGA - Power Meter Advanced - OuterVision Power Supply Calculator Or just add up the Total watts of power for each part of your PC ... use a web search to find values Make Sure the PSU you buy has enough of the Connectors you need sometimes that means getting the next size larger IMO - PSU should be oversized by 20% of expected Max Watts needed So, if your OC CPU, GPU & other items = 1000W --> then get a 1200W PSU Yes, a 1000W load can work with a 1000W PSU but will it last for 5 to 10 years ? & what about future updates - seems the next gen GPUs are power hungry
Ok this is what I really needed to know. I wasn't sure if I should go with a 1,000w or 1,200w, and now I know to get a 1200w. Thanks again guys for being really helpful. It's always good to buy from EVGA.
yaymz
2022/07/20 16:03:37
Keep in mind that EVGA is mandating that you buy the 1600w Supernova P2 if you are planning on buying their 3090ti Kingpin. That should tell you a lot.. And while I'm sure you aren't planning on getting the KP edition, it should give you an idea for where EVGA's head is at. I'd say you can limp in with a 1000w, but if it were me, id go with a 1200w+ (or more) and take advantage of the efficiency rating of your PSU and try to get to an approx. 50% avg load rating with plenty of overhead for power spikes.
post edited by yaymz - 2022/07/20 16:06:29
cpu: Intel 12900k-EK Quantum Magnitude waterblockmobo: Asus z690 Apexram: G.skill DDR5 @ 6000+. gpu: MSI 4090 Suprim Liq x on EK-Quantum Vector² Trio ABP waterblockssd: Samsung m.2 980 Pro 2TB (x2)psu: beQuiet Dark Power Pro 1500wcase: Lian-li o11d xl monitor: Asus ROG Swift 27" 1440p @240hz (PG279QM).[/
dacosa
2022/07/20 17:26:17
hello, where is the stock of supernova 1600w T2? here in Europa imposible to buy thanks a lot regards
Hoggle
2022/07/21 00:19:13
One thing that is worth considering is the new PCI-E Gen 3 connectors are starting to show up. It won't really matter for the 3090Ti but it will matter for what you replace it with but for a 3090Ti it will likely be years before that happens.
Epsolike
- Ribbons : 17
2022/07/22 01:25:03
dacosa hello, where is the stock of supernova 1600w T2? here in Europa imposible to buy thanks a lot regards
We don't have the old units in europe right now, but P+ 1600 and G+ 1600 can be found here. There is also stock of G+ 2000, P+ 1300, G+ 1300, GT 1300, P3 1200 and P2 1200 and ofcourse multiple of 1000w units.
EVGA X570 DARK (1.09) [manual SoC, AUTO high!]AMD Ryzen 5800X3D [-25 -25 -25 -20 -25 -25 -25 -25]GSKILL Royal Elite (Gold) 3600C14 (B-die) [F4-3600C14D-32GTEGA]EVGA 3080 Ti FTW3 UltraEVGA SuperNOVA P6 1000
jonkrmr
- Ribbons : 16
2022/07/23 13:50:45
yaymz Keep in mind that EVGA is mandating that you buy the 1600w Supernova P2 if you are planning on buying their 3090ti Kingpin. That should tell you a lot.. And while I'm sure you aren't planning on getting the KP edition, it should give you an idea for where EVGA's head is at. I'd say you can limp in with a 1000w, but if it were me, id go with a 1200w+ (or more) and take advantage of the efficiency rating of your PSU and try to get to an approx. 50% avg load rating with plenty of overhead for power spikes.
Not sure where you got that EVGA is mandating that you buy a 1600w SupperNova P2 power supply for the KingPin. EVGA recommends at least a 1000w power supply for it. They were just bundling their 1600w P2 power supply with it most likely to get rid of overstock of the 1600 P2 which you can imagine is not a huge volume seller.
Intel i9-10850K @ 5 GHz MSI MEG Z490 Unify Corsair Vengeance RGB RT 32GB 3600MHz DDR4 ASUS Strix RTX 3080 OC 12GB Gaming @ 2175 MHz core - peak \ 20004 MHz mem Samsung 970 EVO Plus 500GB NVMe M.2 SSD 2x Samsung 970 EVO Plus 2TB NVMe M.2 SSD RAID 0 SoundBlasterX AE-5 EVGA SuperNova 1000 P2 Corsair Obsidian 500D SE Custom water cooling on CPU & GPU Acer XV272U 27" 2k 170Hz
yaymz
2022/07/23 21:21:50
You cannot buy the 3090ti KP by itself. They only sell it bundled with that PSU..
jonkrmr
- Ribbons : 16
2022/07/24 13:31:50
yaymz You cannot buy the 3090ti KP by itself. They only sell it bundled with that PSU..
Yes, correct but that does not mean that EVGA is mandating you use that PSU with the KP. EVGA recommends at least a 1000w power supply for the KP. If I remember correctly when the KP was in stock, the price for it was such that they were pretty much giving the 1600 T2 PS away.
post edited by jonkrmr - 2022/07/24 13:34:33
yaymz
2022/07/25 11:40:32
jonkrmr
Well that is why I prefaced what I said with "buy" and not "use" . You are correct in that that they stop just short of saying "you must use the 1600w P2", it is sorta implied here. Also, I don't buy that they are just "giving away" a random PSU with their brand new flagship GPU. EVGA is saving themselves a lot of hassle and headache of customers just buying a KP and then just using whatever PSU falls with-in minimum spec and having a lot of customers rage that their systems are crashing to transient load spikes.
spartakrex
2022/07/25 14:37:46
Any reason you have to ask and not just get a top-of-the-line PSU given you want to power the flagship GPU? I have one system with a single 3090Ti powered by a 1300W EVGA P+ Platinum and one system with dual 3090Tis powered by a 1600 T2. Each works fine. Neither of the three GPUs is the KPE.
