Re: Visual and Performance issues after 4 different PC builds with different parts
2021/09/02 20:39:14
Look at the NVCP settings you posted, you definitely have some stuff wrong.
It's definitely a configuration problem. You should definitely be using G-Sync.
Try these settings in 3D Management:
Low Latency Mode: Ultra
Max Frame Rate: 141
Monitor Technology: GSync Compatible (when you enable it in monitor OSD/settings)
Power Management Mode: Normal
Preferred Refresh Rate: Highest Available
Vertical sync: On
What about your BIOS/UEFI settings? 3900X can be finnicky if you aren't configuring that correctly either. Are you using CPPC/PSS support? Are you running a negative offset on vcore? These things can cause instability as well.
Let us know.
