spit051261
When I finally get the chiller to cool both CPU and GPU , is it better to T off for feed and return or just have the loop in and out to both in series. Thought I might get better flow and cooling in parallel. Thanks again.
Gaming Rig - Lian Li Dynamic XL, MSI Z490 Godlike, i9 10900k (SP 88) delidded with Rockit IHS, G-Skill 4266 RAM 2X8 , MSI Z Trio 2080ti, Aorus RGB 360 AIO, EVO 2Tb 970 Plus Nvme,1600watt P2, Acer Predator X27 Monitor, K95 Platinum, G502,G560, ST100 RGB, Void RGB Elite.OC Rig - Lian Li T70, Apex XII , i9 10900k (SP 93) delidded with direct die cooling, G-Skill 4000 2X8 Cl15-16-16 RAM , Evga KPE 2080ti, 2 x 1 Tb Evo 970 Plus Nvme, Evga 1600watt P2, EXC 800 Chiller.
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: Using Y or T piece for CPU and GPU.
2020/02/12 07:43:50
Probably best to go series, GPU first. If you go with parallel, and one block provides more resistance than the other, you may lose some flow across the fins.
In series, the GPU won’t hear the water all that much, if at all, and then the cpu will still get cold water.
the_Scarlet_one
- Ribbons : 79
2020/02/12 07:46:56
You could also go parallel by run to the inlet run to one side of the GPU, pass through and into the inlet of the cpu, the out of the CPU into the GPU, as well as out at the same time. I will try to grab you a picture. You do not need any Y’s or T’s. Like this: The inlets are both on the left, the outlets both on the right. Parallel.. confusing looking, but still parallel. It will also use the same amount of fittings you would have required when considering the other method for parallel, without the Y's and T's.
post edited by the_Scarlet_one - 2020/02/12 07:50:25
2020/02/12 08:08:56
the_Scarlet_one Probably best to go series, GPU first. If you go with parallel, and one block provides more resistance than the other, you may lose some flow across the fins.
I agree - back pressure will determine flow through any device This would give a larger flow of coolant through the device with the least resistance Of the OPs choices listed = "Y" is the winner - less turbulence Interesting photo of a parallel setup - posted by the_Scarlet_one
a213m
- Ribbons : 20
2020/02/12 14:57:26
In parallel connections liquid flow will be lower through more resistive block, so in general it's recommended to go in series, unless you want to run the same blocks in parallel, that way the flow rate will be the same.
My free and open source SDR-DDR5 SPD reader/writer with write protection capabilities New: 13900K, Z790 HERO, 2x32GB 6800C32, 4090, 2TB SN850, AX1600iOld: 10980XE, X299SE2, 8x8GB 4000C15, 4090, 2TB SN850, AX1600i
