Using De-ionised water to clean watercooling kit
Knightviper
2020/01/12 04:29:29 (permalink)
Hi all I will be getting my first watercooling loop delivered today. I'm getting the Thermaltake Pacific R360 Water Cooling kit, 3x Blue Riing 12 LED fans, 360mm Radiator, D5 Pump, Blue Coolant, Fittings. I cant find any distilled water for sale locally to flush the radiator out prior to building the loop, all that I can find is de-ionised water. the Kit comes with a litre of coolant but I dont want to waste it flushing out the rad for the first time, would it be safe to use the de-ionised water to do the cleaning of the rad and other components?
EVGA Z270 Classified K, Intel core i7 7700k , EVGA CLC 280 AIO, 16GB G.Skill Trident Z RGB @3200MHz, 250GB Samsung Evo SSD, Samsung Evo 840 250 SSD, 1TB WD Caviar Green
EVGA 1070Ti FTW 2
EVGA 1300w G2
Windows 10 64-bit
Evga DG-87
5 Replies Related Threads
    awalleyeguy
    • Ribbons : 12
    Re: Using De-ionised water to clean watercooling kit 2020/01/12 06:26:43 (permalink)
     Seems both will work. Distilled vs deionized
    recovered by Cool GTX
    post edited by Cool GTX - 2020/01/12 12:21:40
    awalleyeguy
    • Ribbons : 12
    Re: Using De-ionised water to clean watercooling kit 2020/01/12 06:35:15 (permalink)
    Both will work
    awalleyeguy
    • Ribbons : 12
    Re: Using De-ionised water to clean watercooling kit 2020/01/12 06:35:35 (permalink)
    • Ribbons : 122
    Re: Using De-ionised water to clean watercooling kit 2020/01/12 12:20:08 (permalink)
    awalleyeguy
    I see you have been having some issues with the Spam Filter
    • Ribbons : 122
    Re: Using De-ionised water to clean watercooling kit 2020/01/12 12:59:53 (permalink)
    look for UV treated  or revers osmosis treated water --> less likely to have anything in it that can contaminate your loop
    I usually start with Hot tap water -- if I suspect any large amount of contamination
    then rises several times with "clean" water
