AnsweredHot!Unable to change the color of LED (NU Audio Pro)
npthaiduong
2021/02/24 08:32:43 (permalink)
Hello,
I recently did a fresh installation of Windows 10 for my system, and after I installed the latest driver for the NU Audio Pro, I can no longer change the color of the LED. For example, if I change the LED mode to Static, the color circle stays with white color and becomes "non-clickable". I did experience this issue before, but somehow, I got it fixed after reinstalling the Windows. I have tried these steps but still couldn't get the issue fixed:
- Reinstalling the drivers (1.0.3 version).
- Removing/disconnecting the card from PCI slot (remove and re-insert the SATA power cable as well). Reinstalling the card but still unable to change the LED color.
Has anyone else experienced the same issue?
d3x74
Re: Unable to change the color of LED (NU Audio Pro) 2021/09/23 09:50:20 (permalink)
Yes, I am encountering this issue too. The modal dialog to change the color is not popping up.
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2021/09/24 22:14:55 (permalink)
I see that too. It used to work on this build, so I'm betting a Windows update did something.
I submitted a support ticket here. It might be a good idea to do the same.
post edited by BizSAR - 2021/09/24 22:44:44
BizSAR
EVGA 3090Ti FTW3 Ultra - ASUS ROG PG279QM
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2021/10/08 17:55:28 (permalink)
Same issue installing on a fresh .iso build of Win11 Pro, 22000.194. I've got a ticket in.
BizSAR
d3x74
Re: Unable to change the color of LED (NU Audio Pro) 2021/10/10 15:58:02 (permalink)
Is there a way to change this via a registry entry?
Might be stuck with the current LED color for a while :)
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2021/10/10 16:21:47 (permalink)
Maybe. Verified the same issue is occurring with the older 1.0.2 release version as well.
I'd suggest submitting a support ticket.
BizSAR
d3x74
Re: Unable to change the color of LED (NU Audio Pro) 2021/10/10 16:46:00 (permalink)
Done
d3x74
Re: Unable to change the color of LED (NU Audio Pro) 2021/11/24 13:00:28 (permalink)
P.S.
Since I am not sure when this issue will get resolved, you can change the LED colors in user.config xml file for your card located in your local app data folder.
Exit the app and it will load the RGB value from the file when you restart the app and go into the LED section
KidDaGoat1
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/09 20:05:58 (permalink)
This issue still hasn't been addressed.  I just did a reinstall of windows 11 on my PC and this issue came up.  Contacting support resulted in a reinstalling of the card and the drivers.  The issue persists.
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/15 15:48:46 (permalink)
Same here. All I can get is white still.
BizSAR
Redmane
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/16 09:42:00 (permalink)
Hello,
same for me. Just white and i can`t click to change the led colours.
Windows 11 Pro, 22H2, newest build.
A clean install didn`t change anything.
EVGA_Lee
  • Ribbons : 14
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/17 09:23:42 (permalink)
Sorry for the long delay on this.  Looks like there's a compatibility issue between Windows and the application's color unit.  The team thinks it might be a couple weeks before they have a workaround for you guys.
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/17 09:45:54 (permalink)
EVGATech_LeeM
Wow! Thanks for the response and please thank the team working on it, Lee!
BizSAR
Redmane
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/18 03:21:54 (permalink)
EVGATech_LeeM
Hi Lee,
thank you very much for your support on this!
Best regards
VertigoZero
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/22 12:55:53 (permalink)
Speaking of the RGB LED lights, are they able to be controlled by ASUS Armory Crate Aura Synch? It would be cool if the lights could be synched with the rest of the lights in my system.
VertigoZero
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/27 07:45:31 (permalink)
Can the lights on the card be co trolled by any motherboard’S RGB control software, not just ASUS?
the_Scarlet_one
  • Ribbons : 79
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/27 14:34:17 (permalink)
I’m pretty sure the RGB controller for the card is built onto the card. I don’t think the motherboard would be able to control the lights without an adapter from the card to the motherboard, and I haven’t seen one of those advertised.
Could you give OpenRGB a try and see if maybe that would work?
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/02/27 15:10:22 (permalink)
The lights are controlled only via the NU Audio software, to the best of my knowledge. Armory Crate will not.
BizSAR
VertigoZero
Re: Unable to change the color of LED (NU Audio Pro) 2023/03/05 14:04:36 (permalink)
the_Scarlet_one
If/when I get a card, I'll let you know ;)
post edited by VertigoZero - 2023/03/06 15:59:34
KidDaGoat1
Re: Unable to change the color of LED (NU Audio Pro) 2023/03/06 18:45:55 (permalink)
OpenRGB does not work with the Nu Audio Pro.
Redmane
Re: Unable to change the color of LED (NU Audio Pro) 2023/03/17 03:30:33 (permalink)
EVGA_Lee
Hi Lee,
could your team already figure out what's causing this error and will there be an update/workaround soon?
Thanks in advance!
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/04/05 22:15:23 (permalink)
EVGA_Lee
Hi Lee, any update here?
BizSAR
EVGA_Lee
  • Ribbons : 14
Re: Unable to change the color of LED (NU Audio Pro) 2023/04/27 10:50:36 (permalink) ☼ Best Answerby BizSAR 2023/05/05 20:57:02
BizSAR
EVGA_Lee
Sorry for the delay here, but our team couldn't reproduce the issue that people are reporting.  Still, they tried a few things to see if it might make a difference.  Please give this beta driver a shot to see if it helps:
https://cdn.evga.com/nuaudiopro/EVGA NU Audio Pro_1.0.3.2_Win10.exe
#23
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/04/27 11:14:06 (permalink)
EVGA_Lee
Awesome! I'll have to wait to try it until late tonight. :(
Assuming this will also work for Win11?
BizSAR
#24
EVGA_Lee
  • Ribbons : 14
Re: Unable to change the color of LED (NU Audio Pro) 2023/04/27 11:46:49 (permalink)
BizSAR
EVGA_Lee
Correct.  It works for Windows 10 and 11.
#25
Redmane
Re: Unable to change the color of LED (NU Audio Pro) 2023/04/29 11:31:34 (permalink)
Hello,
awesome! That new (beta) driver works fine for me :-)
System:
Build 22621.1635 // Windows Feature Experience Pack 1000.22641.1000.0
Asus ROG Crosshair X670E Hero, AMD Ryzen 7 7800X3D, 32GB DDR5 6000C30, RTX 4090, EVGA Nu Audio Pro
Thank you (and your team) very much!
Best regards
#26
ManBearPig
  • Ribbons : 20
Re: Unable to change the color of LED (NU Audio Pro) 2023/04/29 12:05:17 (permalink)
That's weird. I have a NU Audio Pro and just did a clean Windows 11 install. Installed the software and was able to change my LEDs back to what I had them. Sucks some people are having issues. At least it doesn't look like everyone is affected by this.
#27
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/05/05 20:36:30 (permalink)
ManBearPig
Good to see you again! Good info too. It's been a while since I performed a Win11 reset...
BizSAR
#28
BizSAR
Re: Unable to change the color of LED (NU Audio Pro) 2023/05/05 20:56:41 (permalink)
EVGA_Lee
BizSAR
EVGA_Lee
Yup, performed a clean install of the beta diver. In the app, the LED section, the circle is changed to a square and I can change color.
Thanks to Lee and team for taking a (good) stab at it!
BizSAR
#29
