madmuhammad
Hi all, I have just rebuilt my old system due to relocating countries. The components are as foloows: Rampage V Edition 10 i7-5960X OC'd 4.5Ghz w/i H110i cooler 32GB Corsair Dom RAM 3 x Titan X SC GFX Samsung 950 Pro SSD AX1500i PSU I just added 3 x LG 32GK850G 2560x1440 monitors at 144mhz to run in surround for iRacing My problem is this. I have extremely low FPS at all times. In iRacing it's mainly at 90fps or less, under 50 on some tracks. When I run Valley or GFXBench the fps is very poor also (as low as 15fps on Valley) and when I run anything, benchmarks or games, the cards max out 1315Mhz and 98%+ usage still with poor fps. i have attempted: -Run single monitor: same result -Uninstall drivers with DDU: same result -Uninstalled MSI Afterburner and Precision X: same result -removed and reseated GFX cards -Run benchmarks on 1920x1080: same result -Checked for viruses Any help or suggestions would be much appreciated
EVGATech_AdamB
Re: Titan X 3 way SLI cards running at max with low FPS
2019/02/05 10:00:56
Hello madmuhammad! Have you tested with and without SLI enabled? Some research into that game shows that it may not be optimized very well for SLI configurations, especially a 3-way configuration. Also, have you been able to test with your CPU overclock disabled?
Like our service? Please provide feedback for us at the link HERE.
2019/02/05 10:45:17
Check and see if your cpu is overheating. Have you optimized your games with geforce experience?
madmuhammad
2019/02/07 23:35:18
EVGATech_AdamB Hello madmuhammad! Have you tested with and without SLI enabled? Some research into that game shows that it may not be optimized very well for SLI configurations, especially a 3-way configuration. Also, have you been able to test with your CPU overclock disabled?
Hey Adam. So I've come to the conclusion the Nvidia Surround is the issue, Without Surround all 3 cards idle at 135Mhz GPU clock and 405Mhz mem clock. With Surround enabled the 'idle' at 912 & 3304. I had this configuration running 3 x Sony 50" LCD's at 1920x1080 in SLI with no issues but upgrading to 2560x1440 monitors causes this. I thought with the 3 Titans this looks a little strange? Do you have any idea why this may be? Oh, and I'm running all monitors on separate cards with Display Port now but I did try them on the one card with no difference I haven't tested without SLI as yet. I will try that shortly. (sorry, I've been very busy) Sajin Check and see if your cpu is overheating. Have you optimized your games with geforce experience?
CPU running at 36C at idle and not breaking 60C under load in the game. iRacing doesnt come up in the list for optimisation
2019/02/08 01:20:42
Make sure the slow mode switch on the motherboard isn't set to on.
madmuhammad
2019/02/11 07:27:30
Sajin Make sure the slow mode switch on the motherboard isn't set to on.
Checked and the switch is in the off position.
2019/02/11 08:00:11
Which Nvidia driver ? is it a new one or the same you were using ? OS ?
madmuhammad
2019/02/12 20:58:21
I had the current driver but downgraded to 398.11 as this was working before i rebuilt Using Win10 Home 64 bit
2019/02/12 21:03:51
☄ Helpfulby madmuhammad 2019/02/12 21:05:35
Might be time to try a fresh install of windows on a separate drive.
madmuhammad
2019/02/12 21:06:30
Something I was hoping to avoid but I am willing to attempt anything at this stage
madmuhammad
2019/02/12 23:34:26
Sajin Might be time to try a fresh install of windows on a separate drive.
Clean install done inc removal of driver with DDU. No change sadly
2019/02/12 23:46:20
Load optimized defaults in the bios and see where that gets ya.
madmuhammad
2019/02/13 00:07:47
Sajin Load optimized defaults in the bios and see where that gets ya.
Still same deal mate *sigh* btw Thanks for taking the time to help
2019/02/13 00:22:55
No problem. Do each of your cards show to be running at the above bus interface speed or higher when running valley benchmark?
post edited by Sajin - 2019/02/13 00:34:04
madmuhammad
2019/02/13 00:51:55
yep sure does...
madmuhammad
2019/02/13 00:53:12
All 3 cards look like this as well
post edited by madmuhammad - 2019/02/13 01:19:24
madmuhammad
2019/02/13 01:01:36
Ok. Back into SLI and all 3 GPU's read either x16 3.0 or x8 3.0
post edited by madmuhammad - 2019/02/13 01:18:43
2019/02/13 02:43:33
madmuhammad
2019/02/13 07:35:30
Sajin Try this driver.
Still no change my man. I've included a screenshot of what Precison XOC reads from desktop to iRacing. That isn't playing the games, just loaded track and ready to race. Maxing cards out like crazy
2019/02/13 11:15:41
Very strange. Not sure what the issue is. Was there a reason you were running driver 388.13 vs the latest driver?
madmuhammad
2019/02/13 20:39:14
my only reason for running 388 was that it was the last driver I ran before dismantling my system and moving to Thailand. This morning I've done a clean install of Win10, removed 2 GPU's and I'm running 1 monitor. Lets see how it goes step by step
2019/02/13 20:46:04
Have you checked the cpu socket for bent pins?
madmuhammad
2019/02/13 20:48:00
That's something I haven"t done as yet. Wouldn't that effect my OC though? I've bounced back and forth between stock and 4.6 no probs
2019/02/13 20:49:50
Yep, but certain pins will only affect certain things.
madmuhammad
2019/02/13 20:51:36
ok gotcha. I'm gonna run some stuff single GPU and monitor and work up from there. If all else fails I'll start looking for physical damage
madmuhammad
2019/02/14 21:52:32
No bent pins bro. I pulled cpu, ram, gpus and checked all. Reinstalled with new drivers and still same bs EVGA saying maybe voltage prob so change PSU, I'm not convinced. I'm beat
2019/02/15 01:03:04
Sorry to hear that. You gonna try a different psu?
madmuhammad
2019/02/16 06:24:43
So I checked output of PSU with multimeter and all is fine so its nlt a power issue, I've done a full SSD wipe and fresh install. It looks as though the high idle speeds are just a surround issue as it has low to 0 gpu usage when on the desktop. I"m getting ok FPS with heaven but a lot of stutter. My CPU can't be bottle necked so maybe its just a characteristic of these monitors I think I'm just gonna get a couple RTX 2080 ti's and be done with it man.
2019/02/16 12:03:44
madmuhammad I think I'm just gonna get a couple RTX 2080 ti's and be done with it man.
madmuhammad
2019/02/17 21:50:52
I meant to thank you for your help too, it was very appreciated What is your suggestion for a 2080? I'm thinking EVGA 2080 ti FTW3. Would love to hear your thoughts
