https://www.techpowerup.com/296473/thermaltake-announces-thermaltake-pacific-w8-and-pacific-w9-cpu-water-blocks Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, is constantly pushing limits to provide high- performance cooling solutions for all tech fans, PC builders, PC enthusiasts, and modders. This time, with no exception, introducing two all-new high-performance CPU water blocks, the Pacific W8 CPU Water Block with a full copper design and the Pacific W9 CPU Water Block with an acrylic design, are in stock for purchase now. Built with high-quality materials, the Pacific W8 and W9 CPU Water Blocks aim to suffice even the most demanding users seeking top-tier CPU water blocks.
Pacific W8 CPU Water Block features a copper top and base with anti-corrosive nickel plating; this provides a stunning mirror finishing and prevents material corruption while extending overall durability. On the other hand, the Pacific W9 CPU Water Block also has an anti-corrosive nickel plating copper base, but it comes with an acrylic top cover for a crystal clear inside view, allowing users to showcase colorful coolant passing through the Pacific W8 and the W9 CPU Water Blocks. Pacific W8 and W9 both feature a central inlet design with a jet plate in the middle of the water block, restricting the water flow for even coolant distribution through the optimized 0.2 mm micro-channels. By doing so, the copper plate can quickly transfer heat from the CPU into the coolant, ensuring better cooling efficiency and the best heat dissipation from the CPU.
Features of The Pacific W8/ W9 CPU Water Blocks:
Top-of-the-line Build Quality and Materials
The Pacific W8 CPU Water Block is a full copper design water block with an anti-corrosive nickel plating copper base. Implementing this specialized plating technique can significantly reduce the likelihood of corrosion after an extended period of use and, most importantly, keep it shiny all along. As for the Pacific W9 CPU Water Block, it also features an anti-corrosive nickel plating, reducing the possibility of corrosion and extending its durability. Besides, the acrylic top cover with an absolutely crystal clear inside view allows you to showcase your build's simple and elegant aesthetics.
Central Inlet Design
The Pacific W8 / W9 CPU Water Blocks both feature a central inlet design with a jet plate located in the middle of the CPU water block, so that coolant can contact the heat source evenly and directly, thus resulting in greater heat dissipation from the CPU.
Optimized Micro-Channels
The optimized 0.2 mm micro-channels of the Pacific W8/W9 CPU Water Blocks are designed to seamlessly enable coolant to be distributed in a separate direction, transferring heat from the heat source effectively and achieving well-rounded heat dissipation.
Powerful Liquid Metal Thermal Grease Included
Selecting the Pacific W8/ W9 CPU water blocks will give you early access to our very first liquid metal thermal grease—TG-60. The TG-60 is designed for high-performance CPUs and GPUs with an extremely high thermal conductivity of 52 W/mK, providing unparalleled cooling efficiency that can boost your cooling system even more.
Caution: TG-60 Liquid Metal Thermal Grease contains corrosive substance; please do not make contact with aluminium materials.
To further enhance the overall cooling performance, the Pacific W8 and the W9 CPU Water Block also come with Thermaltake's first liquid metal thermal compound, TG-60. TG-60 has an extremely high thermal conductivity of 52 W/mK that could aid your cooling system even more, so get the W8/ W9 CPU Water Block and gain early access to our liquid metal thermal compound. For compatibility, the Pacific W8 and the W9 CPU Water Blocks support most Intel and AMD universal sockets, including AM5 and the latest Intel LGA1700 sockets.
For all the working professionals and gaming enthusiasts, if you plan on upgrading your water block, you won't go wrong with either the Pacific W8 CPU Water Block or the Pacific W9 CPU Water Block.
Universal Compatibility
- The Pacific W8 / W9 CPU Water Blocks are both compatible with the latest Intel LGA 1700 and AMD AM5 sockets. It also supports Intel and AMD universal brackets for superior compatibility except for sTR4, sTRX4 sockets. As a result, PC builders no longer have to worry about requiring additional brackets.
- Intel: LGA 2066/20113/2011/1700/1200/1156/1155/1151/1150
- AMD: AM5/AM4/AM3+/AM3/AM2+/AM2/FM2/FM1
For more information, visit the product pages of the
Pacific W8 and
Pacific W9.
Nice to know AM5 is supported already.
