whisperingshadow
Thanks all for the input on parts etc I bought this stuff last night: Evga DG77 black Samsung 500gb 970 evo Evga G3 850w i7-8700k with clc 280 Ballistix 32gb sport LT dd4 Evga 1080 FTW hybrid Evga z370 FTW Acer Predator xb1 xb271hu bmiprz 27" ips with gysnc :)
i7 8700k,z370 FTW, Ballistix 32gb ddr4, 3080 Hybrid ftw ultra, 2x-512gb 970 evo, Lian Li o11 Dynamixc XL, clc 280, 850 G3, z370 FTW, 27" Predator IPS Gsync https://www.3dmark.com/3dm/57041776? Associate code for a discount for you BGEX2DBF0D (old/rebuilt)"RE-VGA" i7 8700k,z370 FTW, Ballistix 32gb ddr4, 1080 Hybrid, 2x-512gb 970 evo, DG77, clc 280, 850 G3, z370 FTW, 27" Predator IPS Gsync (old Pc)q6600 @ 3ghz Evga 680sli win10 with 8gb Ram,60gb ssd(OS), 74gb raptor(game), 320gb sata (storage)Evga GTX 980 sc,750w PSU
- Ribbons : 84
Re: Thanks for the input on parts and stuff
2018/05/13 08:49:58
That is going to be an excellent upgrade from your Q6600 processor and motherboard.
thunder-93
2018/05/13 09:23:55
Have fun! Post some pics!
v/r Thunder-93 (Affiliate Code: F8CE835X1W) i7-8700K / Asus ROG Strix Z370-E / EVGA 1080Ti FTW3 Hybrid / EVGA G3 750W / Thermaltake RGB 360 / TridentZ RGB 32GB DDR4-3200CL14 / 960 Evo / 970 Evo / 860 Evo / Firecuda SSHD / InWin 303C RGB
jeffro66
- Ribbons : 8
2018/05/14 15:31:54
now that's a good upgrade congrats
whisperingshadow
2018/05/14 20:29:36
Just got my clc 280 today. Way bigger box than i expected.
whisperingshadow
2018/05/18 14:11:41
Pic of all my parts(Except HDD due to another Fail by Fedex @Bloomington)
2018/05/18 14:25:17
Looks like you'll have a great weekend for the CLC set the MB header to 100% power
thunder-93
whisperingshadow
2018/05/20 17:52:44
So i have still waiting on the HDD (970 m2 512gb), but i pretty much have it all together otherwise. I will write-up a big review once done. The case is beautiful and overall very roomy. With the clc280 mounted in front(fans reversed to intake), the hybrid can only mount in the rear. You will have to remove the top case fan since the radiator from the hybrid cant be installed with it there. So i pushed it foward to the middle stop on top. There is a front top stop that a fan could mount but the case wiring is something in the way(I still might do since 1 fan at top isnt enough i think). The vertical mount wouldnt fit, 1 screw hole is off due to the bottom of the mount(will put pic later). I think if the case were 1-2 inches higher then all the issues would be fixed so that the motherboard parts dont interfere, etc. Some of the instructions were vague or non-existant(reason ill be doing a write-up to help others)
2018/05/21 15:21:23
look forward to your write-up
