Temporary solution for my 3070 TI sag
Epicmango1
2021/10/26 08:26:06 (permalink)
Lol I placed the phone holder thing you place on a tripod under it to hold it up.
My associate code: LKJ9U0W30RBNRV7
18 Replies Related Threads
    aka_STEVE_b
    EGC Admin
    • Ribbons : 65
    Re: Temporary solution for my 3070 TI sag 2021/10/26 08:32:49 (permalink)
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64 .....Associate Code: E54ARBK1Q0ZQ84O .........
    ................ GET UP TO A 10% DISCOUNT ON PURCHASES BY CLICKING ............
    Epicmango1
    Re: Temporary solution for my 3070 TI sag 2021/10/26 08:38:19 (permalink)
    Lol
    kswildman
    Re: Temporary solution for my 3070 TI sag 2021/10/26 08:54:54 (permalink)
    Adapt and overcome at its finest!
    AMD Ryzen 9 5900X (No OC)
    ASUS Prime X570-Pro
    32GB G.SKILL Trident Z Neo CL16 3600
    EVGA CLC 280mm All-In-One
    SAMSUNG 980 PRO SSD 500GB - PCIe 4.0 NVMe SSD
    EVGA SuperNOVA 1300 G2 80+ GOLD
    EVGA 3080 FTW3 Ultra Gaming
    Lian Li Lancool Mesh II RGB
    Epicmango1
    Re: Temporary solution for my 3070 TI sag 2021/10/26 08:56:30 (permalink)
    Yeah hah
    staypuft
    • Ribbons : 26
    Re: Temporary solution for my 3070 TI sag 2021/10/26 09:05:20 (permalink)
    Interested in a discount on EVGA products?
    Click here for details and enter my Associates code at checkout >> 2ILPLQQ8IWY8DPN
    Don't forget to REGISTER your product... click my code here to begin registration >> XF8WVJBE5G
    2021 Build: Gigabyte Z590 Ultra | Core i7-10700K | be quiet! Dark Rock Pro 4 | 32GB G.Skill Trident Z DDR4-3200
    EVGA RTX 3070 Ti XC3 Ultra | Samsung 970 EVO 500GB | Seasonic Focus GX-850 | Fractal Design Meshify C
    Epicmango1
    Re: Temporary solution for my 3070 TI sag 2021/10/26 09:07:59 (permalink)
    staypuft
    $9 on amazon
    https://www.amazon.com/dp/B08CDDSWKR?psc=1&ref=ppx_yo2_dt_b_product_details
    Yeah I'll buy one soon but I'm thinking of getting one of those horizontal ones instead
    ObscureEmpyre
    Re: Temporary solution for my 3070 TI sag 2021/10/26 09:43:37 (permalink)
    I’ve been tempted to get a statue of Atlas to hold mine up.
    Gotspeed_2000
    Re: Temporary solution for my 3070 TI sag 2021/10/26 10:26:44 (permalink)
    You might want to take a look at Lian Li's anti sag gpu kit.  It comes with their O11XL case and I use the kit for builds where the mobo has exposed mounting screws on the right side or middle of the board.  The picture off amazon's website shows it supporting the GPU from the middle mounting points of a atx mobo.  I like to use the along the right side of the atx mobos if possible.  These would be the lower right and the right middle mounting screws.
    https://www.amazon.com/dp/B07YKGKZWP/ref=olp-opf-redir?aod=1
    This kit does help keep the build looking clean without having to add a stand brace.
    Lian Li O11 XL
    AMD 5950X - Optimus Foundation CPU Water Block
    EVGA 3090 FTW3 Ultra - Optimus Absolute GPU Water Block
    Asus Dark Hero X-570 Mobo
    32gb Trident Royal RAM
    500gb Nvme primary drive
    1tb Nvme secondary drive
    1tb SSD drive
    EVGA 1200 Watt Supernova PSU
    10 Lian Li AL120 fans
    Lian Li Strimmer Kit - 24 pin MOBO and 24 Pin VGA
    EK Pump/Res Combo
    2 PE Coolstream 360mm Rad/1 SE Coolstream 360mm Rad
    Samsung G7 32" Monitor
    EVGA Z20 Keyboard
    Glorious Model O
    BizSAR
    Re: Temporary solution for my 3070 TI sag 2021/10/26 10:57:49 (permalink)
    So what is the best overall solution to this that people have found, other than that already mentioned?
    BizSAR
    EVGA 3070Ti FTW3 Ultra - ASUS ROG PG279QM
    DuleyBC
    Re: Temporary solution for my 3070 TI sag 2021/10/26 11:30:10 (permalink)
    You can also use one of those wooden sticks that you get when you buy paint can. I cut it to the exact size and glued some foam on top to avoid scratching the shroud
    Or you can use anything else that has the perfect size.
    Ok, no worries as now I have a proper bracket for this build.
    staypuft
    • Ribbons : 26
    Re: Temporary solution for my 3070 TI sag 2021/10/26 11:34:02 (permalink)
    Here's the $9 UpHere vertical post design installed inside my PC with the components in sig.
    cjake
    Re: Temporary solution for my 3070 TI sag 2021/10/27 00:38:24 (permalink)
    I purchased this 3D printed adjustable height stand on Etsy.  The sellers shortest stand was perfect height in my mATX case.
    Mini Adjustable Graphics Card Stand Support Brace Anti Sag GPU | Etsy
    post edited by cjake - 2021/10/27 00:41:53
    Epicmango1
    Re: Temporary solution for my 3070 TI sag 2021/10/27 00:44:23 (permalink)
    staypuft
    Nice
    Back_Yard_Gamer
    Re: Temporary solution for my 3070 TI sag 2021/10/27 06:57:22 (permalink)
    It was simple maths really 1+2= No GPU Sag!
    https://ibb.co/M7N1M6J
    https://ibb.co/sQRz1Vj
    Professional Spammer with a PHD in Spamology & The Illogical Logic of Spam. Author of "Would you like cheese with that Mr Mann?"
    My living Room Please don't put yer feet on the table, its new!
    sethleigh
    Re: Temporary solution for my 3070 TI sag 2021/10/27 07:38:02 (permalink)
    Gotspeed_2000
    Thanks for linking that! I'm looking into what I'll need when the Optimus block shows up for my 3080ti FTW3. It's going to take something, because that block weighs like 6 lbs or something with the backplate, and I don't think it's good for the PCIE slot to have all that weight hanging off it with just the two screws on the far left helping to support the weight. That solution looks pretty decent to me.
    Happy EVGA customer.  Affiliate Code: 0Y7-1VU-ATW2
    GigaByte X570 Aorus Master, AMD Ryzen 5900x, 32gb G.Skill DDR4 @ 3800 MHz 14-15-15-28, EVGA 3080ti FTW3 Ultra, 2TB 980 Pro SSD, EVGA Supernova G2 850W PS, ASUS 34" 3440x1440p 120Hz ultrawide, Lenovo 24" 1080p secondary monitor, Win 10
    schmak01
    Re: Temporary solution for my 3070 TI sag 2021/10/27 08:14:07 (permalink)
    Jayz had a good video on how to fix this for free, using old bracket covers.  It's not elegant, I used the Coolermaster horizontal bracket in both my cases, but for vanity/looks.
    Not cheap, but its very well made
    Amazon.com: Cooler Master ELV8 Addressable RGB Vertical Universal Graphic Card Holder, Built-in ARGB Strip, Adjustable Length & Height Support : Electronics
    • CPU: 5900X / 3800XT
    • MB: Asus Strix X570-E / Asus TUF B550
    • RAM: 32 GB TridentZ 3200 CL14 (stock timings) / 64 GB Ripjaws 3600 cl 16
    • GPU: EVGA 3080TI Hybrid (converted from FTW 3 Ultra) /  EVGA 3080 Hybrid (converted from FTW 3 Ultra)
    • Storage: Sabrent 2 TB PCIe 4.0 SSD,WD SN750 1 TB PCIe 3.0 SSD / 2x 4TB WD RED Pro, 1x  Sabrent Rocket Pro 1TB,  4x Crucial MX500 2TB
    • Cooling: H115i Pro Platinum / Vetroo 360mm AIO
    • Case: Corsair 680X / Corsair 5000D Black
    Gotspeed_2000
    Re: Temporary solution for my 3070 TI sag 2021/10/28 01:42:20 (permalink)
    sethleigh
    Gotspeed_2000
    Depending on the case and your budget you might want to look at a vertical mount and a Gen 4 riser cable.  I know the combo is going to run about 125 for both items, but depending on your setup it would make supporting your gpu much easier with less strain on the mobo.  I bought imo one of the better gaming mobos in the Dark Hero and didn't want to have issues later with the PCI-E slot being worn or damaged by supporting the weight of my GPU with the waterblock.  EKWB has a real nice vertical mount in two designs.  One design is to be used when you have cross members on the rear pci-e slots on the case with an offset to allow the use of a vertical mount and the other is for a flush mounting for cases with no obstructions with no offset.  I like the EKWB design since it also uses the mobo mounting posts either down the middle or the right side of the mobo to help support the vertical mount bracket.  By using the vertical mount it takes the stress off the slot to help support the weight of the gpu.  The Lian Li anti sag brace is something I use in most of the air cooled builds I do for others.  If you are really going to put something a bit heavy, I'd also look for a post style brace to help spread the load.  I used the Lian Li kit with my 3090 FTW3 while I was using with the air cooler with no issues or sag.  I went with the vertical mount from Lian Li when I opened loop my system.  With the Optimus block, using the vertical mount really helps show off the gpu block well.  When you don't vertical mount it, the heat sink rear plate is shown more which is why I went with the vertical mount.
    Lian Li O11 XL
    1tb SSD drive
    EK Pump/Res Combo
    EVGA Z20 Keyboard
    Glorious Model O
    sethleigh
    Re: Temporary solution for my 3070 TI sag 2021/10/28 09:52:09 (permalink)
    I ordered that Lian Li kit off Amazon and it arrives today. The Optimus block isn't here yet, though, so it'll be a few days, hopefully not a few weeks, then they'll both get installed. There's no way I want the enormous mass of that thing supported by just the two PCI-E port bracket screws and the PCI-E slot itself.
