Helpful ReplySuperNOVA 750W G2--Case Fan Power?
kephafan
2014/08/11 11:00:21 (permalink)
Hello and please excuse my newbie question.
I will be purchasing this power supply but I'm not sure how the 3- and/or 4-pin fans are powered.
I think I understand that the fans fall under "PERIF1" on the PSU.  Do the supplied molex cables have 6-pin male plugs?
Will I need a splitter since there is only one PERIF1 plug?  (Nah, I'm not confused at all.)
Thank you,
kephafan
[<font]ASRock Z97 Extreme6 ATX LGA 1150--Intel Core i7-4790K 4.0 GHz Quad-Core LGA 1150--Antec KUHLER H2O 950 120mm Liquid Cooler--Corsair Vengeance Pro 8GB (2x4GB) DDR3-1866 (blue)--Sapphire VAPOR-X R9 280X 3GB 384-bit--EVGA SuperNOVA 750 G2 80+ Gold Modular--Thermaltake Overseer RX-I ATX Full Tower--Crucial MX100 256GB SATA III MLC 2.5" SSD--WD Blue 1TB 3.5" 7200 RPM HDD--Windows 8.1(64-bit)
vsg28
  • Ribbons : 18
Re: SuperNOVA 750W G2--Case Fan Power? 2014/08/11 12:14:05 (permalink) ☄ Helpfulby kephafan 2014/08/11 13:05:06
The SATA and Perf1 plugs are interchangeable. But you will need a splitter or a 3/4-pin to Molex/SATA adapter to power the fans.
kephafan
Re: SuperNOVA 750W G2--Case Fan Power? 2014/08/11 13:05:43 (permalink)
Thank you for clearing that up for me!
vsg28
  • Ribbons : 18
Re: SuperNOVA 750W G2--Case Fan Power? 2014/08/11 13:28:59 (permalink)
No problem
sahafiec
  • Ribbons : 7
Re: SuperNOVA 750W G2--Case Fan Power? 2014/08/12 00:44:09 (permalink)
you get a 4 pin molex cable which can power at least 4 fans without using extra splitter (only molex-374pin adapter needed).
http://www.techpowerup.co...uperNOVA_G2_750/3.html
i5 6600k | z170 m8g | bequiet pure rock | gtx1070 FTW | 2x8gb 2666mhz | 250gb m.2 & 2tb | 650W P2 | Enthoo Pro M Acrylic | pb258q
