Super Serial about my first custom water loop FINISHED
ManBearPig
  • Ribbons : 20
2019/06/08 09:01:32 (permalink)
I've been wanting to have a loop ever since I started building computers. I finally decided to do it, and went all out for my first time.
Parts:
EK Vector RTX RE Ti RGB - Nickel + Plexi
EK-Vector RTX Backplate - Black
EK-Velocity D-RGB - Nickel + Plexi
EK-CoolStream CE 420 (Triple)
EK-CoolStream SE 420 (Slim Triple)
EK-XTOP Revo D5 RGB PWM - Plexi
FrozenQ LF Reaction 250mm Reservoir - UV Blue Helix
EK-Furious Vardar EVO 140 BB 2500rpm - Black (6)
EK-DuraClear 9,5/15,9mm (3/8" x 5/8") Tubing - Transparent
EK-UNI Pump Bracket (140mm FAN)
Mayhems Biocide+ - 15ML
EK-ACF Compression Fitting 10/16mm (3/8 x 5/8") - Black Nickel (12)
A nice clean shot of my "A" chip :)
Doing a leak test.
I've always wanted a double helix reservoir.
Everything hooked up and running great with no leaks thankfully. Noticed I need angled fittings, got some ordered.
Got the angled fittings installed.
Still not done. Want to make the tube from the pump to shoot straight right to the radiator, then straight up to the port for a cleaner look. Will be doing that shortly, but very happy with the results from my first adventure into making a custom loop. This RTX 2080 Ti is a very hot card and really needed this loop. It was the main push that made me do this. Went as big as I could of course, two 420mm rads; one 45mm rad and one slim 28mm rad for the top. Decided to go all EK for this, except the reservoir because they don't make a double helix one. And I had to have that. My next upgrade is the mobo/cpu/ram but am trying to hold out just a little bit longer. This 3820 has really served me well and I sure have gotten my money out of it lol
Edit: new pics
post edited by ManBearPig - 2019/07/21 11:48:16
17 Replies Related Threads
    • Ribbons : 122
    Re: Super Serial about my first custom water loop 2019/06/08 09:21:38 (permalink)
    Nice build
    Maybe I can't see it ?  When you open the loop for updating fittings add a "T" fitting or other way to add a drain to your loop - makes maintenance much easier
    Hoggle
    Re: Super Serial about my first custom water loop 2019/06/08 09:38:43 (permalink)
    Very nice looking for the first time doing water cooling.
    ManBearPig
    • Ribbons : 20
    Re: Super Serial about my first custom water loop 2019/06/08 09:40:28 (permalink)
    Thanks!
    When I ordered the angled fittings, I ordered a T fitting and a ball valve. Ya, wasn't the best draining it when I put on the angled fittings lol. But I installed it at the bottom right after the pump when I did the angles. So all I have to do now thankfully is plug in a tube, and turn the valve. You might not be able to see them because they are black, but it is right after the pump before the angled fittings going up to the front rad. Hard to see, but is in the last pic, look for the shine from the pumps LED.
    ManBearPig
    • Ribbons : 20
    Re: Super Serial about my first custom water loop 2019/06/08 09:45:50 (permalink)
    This is in a EVGA DG-87 case btw
    notfordman
    • Ribbons : 28
    Re: Super Serial about my first custom water loop 2019/06/08 10:54:26 (permalink)
    Much better than my first water cooling attempt MBP! Nicely done. Yeah, I was going to mention the rad to pump line. It's the only one I see that needs a little "prettying up". Couple 90's will fix that up. You should have plenty of rad, I try to go as thick as possible. That way you can slow the fans down. Good job dude!
    • Ribbons : 122
    Re: Super Serial about my first custom water loop 2019/06/08 11:04:08 (permalink)
    ManBearPig
    Keep the photos coming & round out your build log with details & benchmarks
    Did you make any changes to the case ?  Did this require cutting or unbolting ......
    Hoggle
    Re: Super Serial about my first custom water loop 2019/06/08 11:25:48 (permalink)
    Maybe we will see this on mod Monday.
    ManBearPig
    • Ribbons : 20
    Re: Super Serial about my first custom water loop 2019/06/08 12:16:07 (permalink)
    Thanks for the comments everyone
    Thankfully no. Not a single thing was done to the case at all. The reservoir holder came with the case and was super easy to install. I only had to remove the first Hard Drive cage for the pump to fit. But that was easy enough. I didn't notice any correlating holes for the pump on the bottom or HD cage. But I bought an adapter to fit to the bottom 140mm section of the front rad. I could have drilled holes on the bottom for the pump, but I wanted to try and make this without any case modification of any kind.
    My EVGA products in this build: EVGA X79 Dark, EVGA RTX 2080 Ti XC Black, EVGA 1600 G2 with EVGA sleeved cables and combs, and the EVGA DG-87 case
    Will post more soon
    post edited by ManBearPig - 2019/06/09 11:56:07
    ManBearPig
    • Ribbons : 20
    Re: Super Serial about my first custom water loop 2019/06/09 13:35:49 (permalink)
    Here are some more pics
    Here is my Port Royal benchmark
    http://www.3dmark.com/pr/96847
    Will of course be trying for more.
    • Ribbons : 282
    Re: Super Serial about my first custom water loop 2019/06/09 13:43:37 (permalink)
    flasher4q
    Re: Super Serial about my first custom water loop 2019/06/09 14:15:02 (permalink)
    Nice Build
    Asus ROG Strix B550-F gaming
    Ryzen7 5800x
    Corsair Dominator Platinum 32 Gig 3600
    Samsung 1T 980 PRO PCIe 4.0
    Samsung 500Gig 970 Evo PCIe 3.0
    MSI GTX 1080Ti
    Thermaltake Pump/Res combo
    Primochill 2 120x2 Radiators
    Bitspower G1/4" Premium master fittings
    Corsair RM 850x
    CoolerMaster H500P Case
    EK-Quantum Velocity D CPU cooler
    Bose Companion2 Speakers
    • Ribbons : 115
    Re: Super Serial about my first custom water loop 2019/06/09 14:18:55 (permalink)
    Looks great. Good job.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    Vlada011
    • Ribbons : 11
    Re: Super Serial about my first custom water loop 2019/06/13 05:30:27 (permalink)
    Really cool.
    Hard Tubing are not necessary to look cool.
    Do you like these fittings? I can't stop to think about them because I have exactly idea how they look inside case.
    http://www.evga.com
    http://www.intel.com
    http://www.nvidia.com
    https://watercool.de
    http://www.lian-li.com
    • Ribbons : 84
    Re: Super Serial about my first custom water loop 2019/06/14 10:20:15 (permalink)
    An excellent build. Congrats.
    ManBearPig
    • Ribbons : 20
    Re: Super Serial about my first custom water loop 2019/06/21 11:55:51 (permalink)
    Nice Score https://www.3dmark.com/compare/pr/96847/pr/94669
    flasher4q
    Nice Build
    Thanks everyone!
    Vlada011
    Really cool.
    Thanks. I have EK fittings like that and they come in handy. Really like them.
    • Ribbons : 115
    Re: Super Serial about my first custom water loop 2019/07/07 21:16:48 (permalink)
    Nice job on the tubing.
     &nbsp
    ManBearPig
    • Ribbons : 20
    Re: Super Serial about my first custom water loop 2019/07/21 11:45:29 (permalink)
    Got the last part of my loop finished. Reworked the tubing from the pump to my front radiator.
    Still find myself just staring at it at times lol
    So glad I finally took the plunge at went water cooled.
