Strange Problem with Metro Exodus
warcobra
2020/03/30 19:07:56 (permalink)
So I recently started having a problem with Metro Exodus. I have 2 gpus in my system. A Titan X and a 2080 Super. The 2080 Super is my primary Card and connected to my main screen with the Titan X connected to a secondary screen. When I launch the game it used the Titan x and passes the video to my main monitor. The game does not have a graphics selection in the options like some games do. So my question is has anyone had this problem? I don't see any way of setting this up in the ini files for it or anything. Thanks in advance for any help you can lend.
:E5-1660v3 @4.7ghz 22c Idle 61c Load
:Custom Water Loop
:ASUS X99 Deluxe/3.1
:Corsair Dominator Platinum RGB 32gb DDR4 @ 3200mhz
:WD 2TB / Samsung 850 Pro 512GB
:Samsung 970 Evo 2TB NVME
:EVGA RTX 2080 Super Hydro Copper 2145mhz
:EVGA GTX Titan X Hydro Copper SLI 1500/8000
:EVGA 1600T2
:Custom Desk   https://www.modsrigs.com/detail.aspx?BuildID=39791
:36x Corsair SP120 High Performance Fans
http://www.heatware.com/eval.php?id=102641
6 Replies Related Threads
    • Ribbons : 109
    Re: Strange Problem with Metro Exodus 2020/03/30 19:24:07 (permalink)
    Moved to the Gaming section.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    • Ribbons : 197
    Re: Strange Problem with Metro Exodus 2020/03/30 19:59:12 (permalink)
    Disable the titan x via device manager before playing the game. See what that does for you.
    Want to save 5 to 10% on your next EVGA purchase? Just click on the associates banner to save, or enter the associates code at checkout on your next purchase. If you choose to use my code I want to personally say "Thank You" for using it.
    warcobra
    Re: Strange Problem with Metro Exodus 2020/03/31 09:17:45 (permalink)
    So going into it further. So when I stop using the Titan x as a secondary monitor it causes the game to crash at launch. When I click to go into safe mode for the game it uses the 2080 but stuck in DX11. So I am now using the 2080 as both monitor outputs and still can't launch the game without crashing. As soon as I plug my Titan X into the monitor and just activate it as a display but not even the primary and it will launch without crashing and display on the primary monitor even though it is not plugged into it. All I can say is that this is a very random and frustrating problem that I have never had before.
    Edit: I should add this is only with Metro Exodus so far that I have run into.
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 197
    Re: Strange Problem with Metro Exodus 2020/03/31 13:23:21 (permalink)
    Only things I could suggest would be to file a bug report with nvidia... https://surveys.nvidia.com/index.jsp?pi=6e7ea6bb4a02641fa8f07694a40f8ac6
    I would also file a bug report with metro exodus tech support... https://techsupport.metrothegame.com/index.php?action=artikel&cat=9&id=1&artlang=en
    warcobra
    Re: Strange Problem with Metro Exodus 2020/03/31 14:52:04 (permalink)
    So I went ahead and bug reported it to them. Seems my specific issue is DX12 with 20 series cards. If it is loading in DX12 the game will crash upon launching. If I load it in DX11 works perfect. With my Titan X, I can load the game just fine in DX12 or DX11. So very strange issue and I have tried all remedies that I can think of and find online. Thanks for your time. I'll update this post whenever I find a fix or a fix gets pushed out.
    :Custom Water Loop
    :EVGA 1600T2
    • Ribbons : 197
    Re: Strange Problem with Metro Exodus 2020/03/31 15:02:25 (permalink)
