- Ribbons : 84
Spire Announces Eagleforce 80 Plus Certified Power Supplies | TechPowerUp Spire is releasing a new series of powerful and dependable 80 PLUS certified ATX power supplies. The EagleForce ATX power supply series aimed at the pc enthusiast en pc gamer. Equipped with selected all high-quality components, supplying optimal power under the most demanding circumstances. The EagleForce units are compliant to the 2.31 version Intel specification standard with advanced circuit design, including better grade A components supporting the newest Intel & AMD dual core & quad core micro-processors. Auto-thermal fan control, maximizing the air cooling performance whilst maintaining reduced sound levels. Energy sufficient and compliant with the Active Power Factor Correction (APFC) Energy Star & 80 PLUS certified standards. As well as ErP 2013 Lot6, which guarantees that your PSU will use less than 1 W on system standby and lower than 45% transferring efficiency on 5 V standby. Housed in cool black powdered coated enclosures and backed by 2 years manufacturer warranty. - 80 Plus certified
- ATX Ver. 2.31 Specification Compliant
- Sleeved flat cables and EZ-Connectors
- EMI Shielded VGA/HDD and Power connectors
- Supports the newest Intel & AMD based systems
- 120 mm silent DC fan PWM fan
- Fan speed Variable by temp-controller
- Completely silent 10.0 dBA up to 45C / 113F
- Active Power Factor Correction (APFC)
- High Efficiency (86%) up to 30% less power consumption
- I/O/OVP/OLP and SCP Short Circuit- Overload- Over Power- & current-Protection
- Output cables: 20+4P *1, 500 mm, SATA+SATA+IDE *1, 500 mm, IDE+IDE+SATA *1, 500 mm, IDE+SATA+SATA *1, 500 mm, P8 (4+4) *1, 600 mm, P6 (2+4) *2, 600 mm
- 2 year manufacturer warranty
ITEM NUMBERS & MSRP: - EAGLEFORCE 500 W ITEM# SP-ATX-500W-80+ MSRP €49,95
- EAGLEFORCE 600 W ITEM# SP-ATX-600W-80+ MSRP €57,95
Although the prices of these PSUs are low I personally find the 2 year warranty to be weak.
