Well back in Sep/Oct last year i did my 6700k build, and at first it was doing great. But then somewhere down the line my MSI Z170 Mpower Titanium mobo began having alot of trouble.
So after i did some tests and mailed back and forward with the vendor where i bought it, i had to send the mobo back as RMA late Jan this year.
After they found out that there was a problem with that mobo, they send me a new one so i could start using my pc again. So here in the start of Feb i got my new mobo and started to rebuild my rig once again.
After a couple of failed win 10 installs, i finally got it all installed and working. So i didnt put that much into the failed tries, was sure that it might just have been win 10 that was doing something weird. So this is what it looked like when i was done with the install of hardware and software.
But then it didnt take long before i start having the same problems again, that i had with the first mobo that i had. So around 14 days after i got the new mobo, it broke down with the same bs problem as the first Mpower Titanium i had.
So once again back to using my good old 2700k, now that i have send the mobo back as RMA again
And this time when we did a couple of mails back and forward, i made it clear that i was done with that mobo and that i wanted my money back from it. It can't be right that i have had 2 of the same mobo's break down with the same error in around 4 months.
So atm my Deepcool case looks a little empty
I'm really hopping that they will give me my money back from this, so i can get another type of mobo after all the problems that i have been through with this build.
If i dont get them back, i guess that i dont should put my tools too far away. But if i do get them back i'm thinking of going back to an Asus type of mobo, and then get a ROG one.
But if i get a ROG mobo i dont think that the name that i gave my build fits anymore. With the Mpower Titanium i called my build Green Titanium Beast, so i need a new name for it.
I was thinking something like The Green Curse or something like that, maybe some of you can come up with some ideas about it.
Okay so i made an strawpoll with the name that is has now and The Green Curse, and any suggestions can be written in the comment of it.
The strawpoll is
here if you want to help me out with a new name for my build, when i hopefully gets another mobo that isn't a Mpower Titanium one.
So i hope that some of you wants to help out and come up with a couple of names or at least cast a vote on one of the two names that i have
