micdoom
Can someone recommend a good sleeved power cable that comes with 8 pin x 3 cables that would work with with my FTW 3 , I'm using an EVGA 1000 G2 the original cables that came with it are hideous , I'm also unable to find a cable kit that comes with 3 x 8 Pin connectors on Amazon, Newegg , Best Buy ... , if you can recommend a cable kit for PCI Express 8 pin , Please note , I am aware of cavle mode however they are way too expensive for what they are.
ROORnNUGZ
Re: Sleeved Power Cables for FTW 3 Ultra
2020/10/19 21:38:19
https://www.evga.com/products/product.aspx?pn=100-NK-1601-B9
This set has 4 8pins
Ciddharthas
2020/10/19 21:47:24
Just be aware that PSU cables are manufacturer-specific. That means that one that works with your EVGA PSU could fry your GPU if you try to use it with a different manufacturer’s PSU, such as Corsair, Asus, Coolermaster, etc. - and vice versa. Some of them route the individual wires in a given cable differently than others. So make sure you get the EVGA cables (since you have an EVGA power supply) and not something cheaper on amazon or whatnot that might not be compatible with your power supply. You might already be aware of this, but I figured I’d mention it just in case.
CPU: i7 10700k @ 5.0 GHz with 360mm Corsair H150i Elite LCD cooler MB: MSI Z490 Meg Ace RAM: 64gb Corsair Dominator Platinum RGB @ 3466 MHz GPU: 3080 Ti FTW3 Ultra Hybrid Power Supply: Corsair HX1000i (1000 Watts) Primary Monitor: LG CX48 (4k OLED) Keyboard: Corsair K95 Platinum RGB Mouse: Corsair Scimitar Elite RGB Headset: Arctis Pro Wireless Mic: Elgato Wave 3 VR: Occulus Quest 2
robnava
2020/10/20 01:40:44
I bought three of these Deep Cool ones from Amazon. They showed up at different times, but they work fine. And at $2.99 each, they’re hard to beat.
DEEP COOL EC300-PCI-E-BK Sleeved Cable - Cable Extension for Power Supply, PSU Cable, PSU Connector, Black, 8 PIN, with Comb
Hoggle
2020/10/20 02:53:18
I would say that the EVGA made ones are the best you are going to find and the best thing about them is since it's an EVGA power supply with EVGA made cables on a EVGA graphics card you don't have to worry about anything going bad and not being covered in using the sleeved cables.
jamexr
2020/10/20 03:36:14
macktkau
2020/10/20 05:39:19
I got cablemods for my Corsair AX 850. I got 5 cables in total. Three individual 8 pin cables because they were half price and pre-made, one cable with a single sata power connector (for my case fan hub) and one cable with a single molex (for my sound card). If I knew how bad the AX 850's 4+4 cables were I'd probably have also got a replacement for those. In the end though I just had to route them a little oddly but I have a closed side panel so the sleeving was more about getting good cable management and no tangles than looking 100% perfect. I just looked at their site and it seems like they've got cables for your PSU on special at the moment. You could get a basics kit and a extra 8 pin modflex cable for $33 USD plus postage, which isn't a bad price. Only problem is the colours are pretty limited.
I_R0M_I
2020/10/20 05:48:24
I've just used extension cables from Shakmods. Done my whole psu last year. Cheaper than buying a kit from manufacturer, plus they look nicer. Braiding is much nicer than most I've seen.
macktkau
2020/10/20 05:49:18
extensions don't help if someone wants to go from using two of the daisychained dual 6+2 cables to 3 normal cables.
micdoom
2020/10/20 09:37:43
Can you please post a link
MatthewAMEL
2020/10/20 10:05:07
Ciddharthas Just be aware that PSU cables are manufacturer-specific. That means that one that works with your EVGA PSU could fry your GPU if you try to use it with a different manufacturer’s PSU, such as Corsair, Asus, Coolermaster, etc. - and vice versa. Some of them route the individual wires in a given cable differently than others. So make sure you get the EVGA cables (since you have an EVGA power supply) and not something cheaper on amazon or whatnot that might not be compatible with your power supply. You might already be aware of this, but I figured I’d mention it just in case.
You have any specific examples? I've never heard of PSU cables being vendor specific. Each block on the PSU corresponds to the plug on the component. If the cable is for a ATX modular PSU, then that's all you need to know.
macktkau
2020/10/20 10:32:16
micdoom Can you please post a link
To what? MatthewAMEL
Only the connections at the end of the cable into the motherboard/graphics card are standard. The connections from the power supply into the cable are not and can vary between companies and even different PSU's from each company can be different. One simple example is that Corsair have "Type 3" and "Type 4" cables. The difference between them is that the 24 Pin ATX cable has a different pin out setting on the power supply.
Little Jay
2020/10/20 10:44:00
Here is a company in the USA that can make custom cables for you if you need.. www.titanrig.com/mod-one-custom-sleeved-pc-cables
