Hot!Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help)
EpicSurvivor
2020/04/02 19:00:35 (permalink)
So I noticed that I have to set CPU_FAN to run at full speed in BIOS if not the Fan speed will not show on Flow Control if I don't don't it also have weird issues where computer will not boot if I don't set the fan to full speed. However this makes the AIO fans run constantly at 1400RPM. Is there a way to fix this? at 1400RPM there's a light hum coming from the fans where as in the slowest fan speed there's no noise.
Also the Fan speed (RPM) on Flow Control does not match the FAN speed on HWMonitor. HWMonitor is showing the right speed which is the BIOS speed of 1400RPM but Flow Control is showing the Fan speed to be at 900. However I know HWMonitor is correct because that's the BIOS Fan speed for CPU_FAN when set to full speed.
I Would like to have the Fan's on the AIO not run at 1400RPM constantly. On Flow Control it shows 900-1020RPM but again this number is not correct. What is the trick here? Really hope someone can help me. Loving my first AIO cooler.
Thank you much!
CPU-Intel ® Core i7 3770K 3.5 (Soon to be OC)
MoBo-ASUSTeK P8Z77 V-LK
GPU-EVGA GTX680 2GB
Memory-Corsair Vengeance (2X4GB) DDR3 1600
OS-Microsoft Windows 7 Professional 64-bit
PSU-CORSAIR Enthusiast Series TX750
Monitor- Asus VG248QE 24" 144hz!!  1MS
Mouse-Logitech G700 with Goliathus mouse Pad
HDD-SAMSUNG Spinpoint 1TB 7200RPM
Case-Rosewill Blackhawk Case (AVOID)
SSD-Pending
Successfully Built on 8/31/12
13 Replies Related Threads
    bob16314
    • Ribbons : 538
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/02 20:26:02 (permalink)
    Did you see Troubleshoot Issues with Flow Control in the EVGA FAQs and try the things shown there?
    Your motherboard will beep (if speaker connected) and not boot unless it detects RPM on the CPU Fan header unless it is set to "Ignore" in the BIOS -> Monitor menu..That's normal.
    Also, you should close all other programs running in the Task Bar and System Tray (Clock area) before installing Flow Control.
    * Corsair Obsidian 450D Mid-Tower - Airflow Edition * ASUS ROG Maximus X Hero (Wi-Fi AC) * Intel i7-8700K (Delidded, TG Conductonaut) @ 5.2GHz* 16GB G.SKILL Trident Z 4133MHz * Crucial MX500 M.2 1TB * WD Black 500GB (x2) * Seasonic M12 II 750W * Corsair H80i V2 * EVGA GTX 760 SC * Dual-Boot Win7 Home 64-bit/Win10 Home 64-bit (Winver 1909) *
    EpicSurvivor
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/02 20:38:11 (permalink)
    bob16314
    Hi again. really sorry for spamming the forums. I am pretty sure this is my last question for now. The only problem I have is that the AIO Fans are running constantly at 1400RPM is there anyway of turning them down? I can't do it on Flow Control. Flow Control is reading the fans at 1020RPM which is different from the BIOS reading but BIOS is correct at 1420RPM. However everything is working fine I just would like to run the fans at lower speed.
    I have set the AIO Header to run at 100% in BIOS if I don't sometimes the computer won't boot for some reason like if I set it to normal. Also if I set it to normal instead of 100% the fan speed won't show on flow control.
    Basically I just want to know if there's anyway as my issue is described above to turn the fans down from running constantly at 1400RPM.
    Thank you
    GPU-EVGA GTX680 2GB
    SSD-Pending
    bob16314
    • Ribbons : 538
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/02 20:56:58 (permalink)
    Only thing I can tell you is to connect the fans to Chassis Fan headers and control them through the BIOS or try the SpeedFan software.
    If needed, you can buy fan cable extensions just about anywhere..You can connect both fans to one header with a 'Y' splitter cable as long as the fans don't draw more than 1 amp combined..The fan amps should be shown on the fan sticker.
    Fan control through EVGA software is less-than-impressive.
    coolmistry
    • Ribbons : 37
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 02:21:29 (permalink)
    EpicSurvivor
    Thank you much!
    Let me ask you where did you plug a 4 pins fan plug from the cooler pump go to?
    Did you plug on to CPU_Fan for cooler pump?
    Windows 10 Home 64bits v1909
    i7 8086k @ 5225MHz delidded || EVGA Z370 Classifieds K || 2 x EVGA GTX 1080 Classified  || 16 gb Dominator Platinum DDR3 3200mhz XMP || 500gb Samsung 970 EVO plus NVMe || 256gb Samsung 970 EVO NVMe M.2 (3 x SSD and 1xHHD) || Killer Wireless AC1550 || EVGA CLC 280 Cooler || EVGA Supernova 1000w G2 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse || EVGA DG 77 case || Acer Predator Z35 35" 160Hz G-Sync v2 Pro || Logitech Z906 5.1 system sounds  SPDIF || Kaspersky Internet Security
    EpicSurvivor
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 07:31:29 (permalink)
    coolmistry
    Okay so I plugged in the AIO Fans to the fan connections on the Pump then I plugged the AIO Fan header to CPU_FAN header on the Motherboard. I tried SYSTEM_Pump but same results.
    GPU-EVGA GTX680 2GB
    SSD-Pending
    EpicSurvivor
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 07:33:03 (permalink)
    bob16314
    Thank you Might give this a try.
    GPU-EVGA GTX680 2GB
    SSD-Pending
    coolmistry
    • Ribbons : 37
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 08:27:09 (permalink)
    I think that CLC software will not work control speed on CPU_fan and I can see you only have 1 x CPU fan and 3 x chassis
    fans
    I use 4 pins pin plug to PWM fan on MB header for cooler pump and set 100% speed and those two cooler fans for radiator with 2 x 4 pins go in to one 4  pins plug to cooler pump. That where in software fans slide control speed and for pump always stay speed because my PWN speed set at 100%
    I can see you don't have PMW fan connector but I think you should set to manual from Auto fan or smart fans on CPU fan and set 100% speed for cooler pump and the cooler radiator fans you can change speed slider up and down in your CLC software.
    If not work then try on SYS Fan to set 100% speed for pump!
    Let us know how getting on...
    post edited by coolmistry - 2020/04/03 08:38:13
    EpicSurvivor
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 08:58:31 (permalink)
    Hi sorry I am using the Gigabyte Z390 AORUS PRO and a i7 9700K at the moment the signature is old need to update it. (Just feel nostalgia erasing it at the moment lol)
    Anyway I made this video hope it helps a little. is the same thing I posted above. EDIT Forgot to mention on the video I am able to turn UP the fan speed in Flow Control just not down.
    HWMonitor and BIOS have the same correct Fan speed reading but flow control is different from the two and is not reporting the correct fan speed
    EDIT #2 the light humming is indeed from the AIO because If I stop both AIO fans the sound stops as well.
    https://www.youtube.com/watch?v=3nzeBa7z6jQ&feature=youtu.be
    post edited by EpicSurvivor - 2020/04/03 09:05:17
    GPU-EVGA GTX680 2GB
    SSD-Pending
    coolmistry
    • Ribbons : 37
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 09:09:35 (permalink)
    Yeah I can see the different speed between HWMonitor to CLC software. I remember this for long time but I am not sure which one is true speed but I think it HWmonitor correct reading and the CLC software maybe error reading but I think if CLC speed at 2945 RPM / 2 = 1472 RPM on HWmonitor. I just guess bro
    To be honest I never use CLC software anymore and I find better way here > Post#4 but it up to you!
    EpicSurvivor
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 09:22:16 (permalink)
    coolmistry
    Alright no problem I'll just run it straight from Motherboard.
    Thank you much! and I promise this is probably my last post about this for a while lol
    Thanks
    GPU-EVGA GTX680 2GB
    SSD-Pending
    coolmistry
    • Ribbons : 37
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 09:28:29 (permalink)
    EpicSurvivor
    coolmistry
    Thanks
    Lol nah it is okay and happy to help as we know we have to stay at home!!! anyway post us back how getting on
    bob16314
    • Ribbons : 538
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 10:13:23 (permalink)
    It should be pretty straight forward like my hardware..Plug the pump into the mobo AIO/Pump header which is set by default in BIOS to run a pump at 100%..Plug the fans into the pump's fan leads..Connect the USB cable..Set the CPU fan header to ignore/disable so the thing will boot, otherwise it won't..Install the software..Done..No muss, no fuss.
    But what is and what should be are two different things sometimes.
    HWMonitor doesn't read my pump/fans rpm properly either, but HWiNFO has a subsection in the Sensors page that detects my H80i v2 that does.
    Good luck with it.
    EpicSurvivor
    Re: Setting up EVGA CLC 240mm fan speed in BIOS (Question/Help) 2020/04/03 10:24:53 (permalink)
    Great thank you!
    GPU-EVGA GTX680 2GB
    SSD-Pending
