Quiz
I have the Corsair Professional Series Gold AX850. Been using it since January 2012 (so 8 years of usage). I also placed an order for an EVGA SuperNOVA 850 P2 yesterday. Waiting for it to arrive. I probably should have asked this question before ordering a new power supply, but oh well. Yesterday, I was playing Apex Legends. About 30-35 minutes in, my PC just turned off. After about 3-4 seconds, it turned itself back on again. My temps are fine and I cleaned/dusted my PC just a few weeks ago. This is the first time something like this has happened. Then I played another 40 minute round of Apex Legends. Everything was fine. After quitting the game and getting back to the desktop, 3-4 seconds later the PC just turned off. This time the PC did not power back on automatically like it did the first time. I tried pressing the power button on the case multiple times and still nothing would happen. I then turned off the main power switch on the power supply, waited 5 seconds, and turned the switch back on and tried booting up the PC. This worked. I got the following events in Event Viewer regarding these two unexpected shut downs. I've been told these events are usually related to the power supply: As for checking my power supply voltages, I don't have a multimeter so I used HWiNFO64. My 3930K is overclocked to 4.2 GHz (24/7) at a fixed Vcore of 1.235 volts. This overclock is not new and it has been in place for quite some time now. At idle: At load (after 1 run of IntelBurnTest at the "Maximum" stress level): By the way, during that run of IntelBurnTest, for the first time my screen flashed off and then back on. It happened once. IntelBurnTest continued and said I passed the test though. Any thoughts?
post edited by Sprkd1 - 2020/03/26 16:59:44
Intel Core i7-3930K | Corsair Hydro Series H100i PRO | GIGABYTE GA-X79-UD3 | 16 GB Corsair Dominator Platinum DDR3 2133 MHz | EVGA GeForce GTX 1080 Ti FTW3 GAMING | Creative Sound Blaster AE-9 | Crucial m4 256 GB | Western Digital Caviar Black 2 TB | Pioneer BDR-206DBK | EVGA SuperNOVA 850 P2 | Corsair Obsidian Series 650D | ASUS ROG Swift PG279Q | 2 x JBL LSR305 + 1 x JBL LSR310S | Microsoft SideWinder X4 | Logitech G PRO X SUPERLIGHT | SteelSeries QcK mini | Microsoft Windows 10 Pro 64-bit
Re: Is my power supply on its way out?
2020/03/21 14:06:07
Lights flicker in your house ... unstable power from the wall ? Is your PC set to resume automatically Voltages in your BIOS screen ... level & stability are both important https://www.evga.com/supp...tails.aspx?faqid=59025 Usually if the PC shutdown under heavy load - that is almost always a bad PSU ... when temps are OK @ 8 years of use your current PSU is probably suspect ... look at Mfg website for their "Tests" & what safety shutdown features your model has
bob16314
- Ribbons : 761
2020/03/21 14:09:30
Those events in Event Viewer just mean that your PC wasn't shut down properly, for whatever reason. Could be your PSU is failing..Unfortunately, sometimes the only way to know if an electronic part is failing is to swap it out with a known good part. Some of the PSU's built-in protections will "latch off" and won't reset unless the PSU is switched off or unplugged, which would explain why it worked again after you switched it off. See how the new PSU works out. Good luck.
- Ribbons : 84
2020/03/23 07:47:59
Since this is a Corsair PSU and not an EVGA PSU moving this thread to hardware
- Ribbons : 84
2020/03/23 07:50:08
Looks like the warranty was seven years so you're just out of warranty.
Quiz
2020/03/25 15:28:24
Received my new power supply few hours ago. Just got done installing it. Ran IntelBurnTest and the power supply voltages seem far more stable (i.e. less fluctuations and stay around where they should be). Also played around 30 minutes of Apex Legends and all is good. I don't know if I am being retarded or what but my PC seems far more "snappier" on the desktop and even while browsing the Internet. Just tried loading www.apple.com and it loaded instantly where as before it would take at least a second or two to complete loading/rendering. Good stuff so far.
bob16314
- Ribbons : 761
2020/03/25 20:29:57
Thanks for the feedback.
2020/03/25 20:49:01
sound like you can go back & Add [Solved] to the Title Happy to see the New PSU fixed what was ailing your PC
GTXJackBauer
- Ribbons : 48
2020/03/25 21:39:14
Sprkd1 Received my new power supply few hours ago. Just got done installing it. Ran IntelBurnTest and the power supply voltages seem far more stable (i.e. less fluctuations and stay around where they should be). Also played around 30 minutes of Apex Legends and all is good. I don't know if I am being retarded or what but my PC seems far more "snappier" on the desktop and even while browsing the Internet. Just tried loading www.apple.com and it loaded instantly where as before it would take at least a second or two to complete loading/rendering. Good stuff so far.
- Ribbons : 115
2020/03/26 11:48:32
Quiz
2020/03/29 01:36:01
Thought I would just mention one small nitpick I had regarding the cables that came with my new SuperNOVA 850 P2. I have the EVGA GeForce GTX 1080 Ti FTW3 GAMING graphics card and it requires two 8-pin power cables. The PCIe power cables that come with the 850 P2 are two 1 x 8-pin and two 1 x 8-pin + 6-pin. It did not come with any 8-pin + 8-pin power cables. I ended up having to use two 1 x 8-pin cables. Other than that, everything's great.
bob16314
- Ribbons : 761
2020/03/29 08:59:42
Sprkd1 I ended up having to use two 1 x 8-pin cables.
It's actually recommended that way. Installation remark for high power consumption graphics cards (Seasonic) "High power graphics cards (above 225 Watts) are usually outfitted with two (or three) PCIe slots (connectors). For performance and safety reasons, Sea Sonic highly recommends the use of two (or three) separate PCIe cables to connect such cards to the power supply." An EVGA GTX 1080 Ti FTW3 can peak at over 300 watts.
Quiz
2020/03/29 09:17:34
Okay, didn't know that. Thanks.
seth89
- Ribbons : 14
2020/04/07 19:15:52
Every PC builder needs to buy a line filtration system for their rig. I use Panamax stuff. the MR4000 is solid. https://www.crutchfield.com/p_299MR4000/Panamax-MR4000.html it will clean the power from the wall and create stable power for your PC. Night and day difference in OCing stability. Buy it used from ebay for half the price, the MR4300 is also awesome.
