Thank you for mentioning Tunebrowser, I'm impressed... might be a nice replacement for foobar.
Unfortunately, I experienced the same thing though it did take more stop/starts to lose audio so it seems more stable than Foobar... TB did give much more info when the driver/stack crashed. Not sure if any of this will help but here is the detail/error log:
2019/11/02 09:58:08,139.811: 2019/11/02 09:58:08,139.809: T008e8: TL08: Start from the middle.
2019/11/02 09:58:08,139.825: 2019/11/02 09:58:08,139.823: T008e8: TL08: Preparing fade.
2019/11/02 09:58:08,139.839: 2019/11/02 09:58:08,139.838: T008e8: TL08: Fade out.
2019/11/02 09:58:08,139.852: 2019/11/02 09:58:08,139.850: T008e8: TL08: Enter fade control.
2019/11/02 09:58:08,139.884: 2019/11/02 09:58:08,139.883: T008e8: TL08: Post PlayerNotify: 7004 [PlaybackBegin]
2019/11/02 09:58:08,144.164: 2019/11/02 09:58:08,144.161: T02d10: TL08: Proc PlayerNotify: 7004 [PlaybackBegin]
2019/11/02 09:58:08,218.178: 2019/11/02 09:58:08,218.171: T008e8: TL08: Opening tune 1 [test.dsf]
2019/11/02 09:58:08,218.927: 2019/11/02 09:58:08,218.922: T008e8: TL08: Creating decoder for file [test.dsf]
2019/11/02 09:58:08,218.980: 2019/11/02 09:58:08,218.975: T008e8: TL08: Device supports DSD, creating DSD decoder.
2019/11/02 09:58:08,219.071: 2019/11/02 09:58:08,219.066: T008e8: TL08: Opening file with RAMDecode:No : test.dsf
2019/11/02 09:58:08,222.946: 2019/11/02 09:58:08,222.940: T008e8: TL08: Opening tune file to decode.
2019/11/02 09:58:08,226.901: 2019/11/02 09:58:08,226.895: T008e8: TL08: Block count 126513152 cause NO fraction in final DSF page.
2019/11/02 09:58:08,226.933: 2019/11/02 09:58:08,226.928: T008e8: TL08: at file: test.dsf
2019/11/02 09:58:08,227.124: 2019/11/02 09:58:08,227.119: T008e8: TL08: Decoding range is block:0 to block:126513152 - 1
2019/11/02 09:58:08,227.273: 2019/11/02 09:58:08,227.268: T008e8: TL08: Opened file: test.dsf
2019/11/02 09:58:08,227.302: 2019/11/02 09:58:08,227.297: T008e8: TL08: 1 Sample:1 bit, 1 Word:8 bit.
2019/11/02 09:58:08,227.635: 2019/11/02 09:58:08,227.630: T008e8: TL08: PLTTrace assigned: 01
2019/11/02 09:58:08,228.123: 2019/11/02 09:58:08,228.118: T008e8: TL08: Stage: [PrepareDevice]
2019/11/02 09:58:08,228.538: 2019/11/02 09:58:08,228.533: T008e8: TL08: --- Preparing device for DSD / 2822400 Hz / 8 bit : [NU Audio]
2019/11/02 09:58:08,228.857: 2019/11/02 09:58:08,228.851: T008e8: TL08: Auto resampler: [If device does not support sample rate]
2019/11/02 09:58:08,228.952: 2019/11/02 09:58:08,228.947: T008e8: TL08: --- Try 1/1: Preparing device by [DSD] 2822400 Hz.
2019/11/02 09:58:08,229.130: 2019/11/02 09:58:08,229.125: T008e8: TL08: ASIOProxyProcess: Call : [Confirm] Param:0
2019/11/02 09:58:08,229.587: 2019/11/02 09:58:08,229.580: T008e8: TL08: ASIOProxyProcess: Done : [Confirm] Result:1 Wait:0
2019/11/02 09:58:08,229.657: 2019/11/02 09:58:08,229.652: T008e8: TL08: Post PlayerNotify: 7005 [SpecUpdate]
2019/11/02 09:58:08,229.795: 2019/11/02 09:58:08,229.789: T008e8: TL08: ASIOProxyProcess: Call : [Prepare] Param:0
2019/11/02 09:58:08,230.096: 2019/11/02 09:58:08,230.087: T014b8: TL08: Prx: 2019/11/02 09:58:08,229.898: T00edc: TL01: Requesting sample mode: DSD (Current: PCM).
2019/11/02 09:58:08,230.141: 2019/11/02 09:58:08,230.135: T014b8: TL08: ASIOProxyProcess: Event: [DeviceBeforeChangeSampleMode] Param:0
2019/11/02 09:58:08,230.182: 2019/11/02 09:58:08,230.177: T014b8: TL08: WaitControl: Before mode change wait: None.
2019/11/02 09:58:08,230.217: 2019/11/02 09:58:08,230.212: T014b8: TL08: ASIOProxyProcess: Done : [DeviceBeforeChangeSampleMode] Result:1
2019/11/02 09:58:08,235.995: 2019/11/02 09:58:08,235.993: T02d10: TL08: Proc PlayerNotify: 7005 [SpecUpdate]
2019/11/02 09:58:10,237.095: 2019/11/02 09:58:10,237.086: T014b8: TL08: Prx: 2019/11/02 09:58:10,236.904: T00edc: TL01: Error: Device does not support sample mode DSD.
2019/11/02 09:58:10,237.147: 2019/11/02 09:58:10,237.140: T014b8: TL08: ASIOProxyProcess: Event: [DeviceAfterChangeSampleMode] Param:0
2019/11/02 09:58:10,237.203: 2019/11/02 09:58:10,237.196: T014b8: TL08: WaitControl: After mode change wait: None.
2019/11/02 09:58:10,237.254: 2019/11/02 09:58:10,237.247: T014b8: TL08: ASIOProxyProcess: Done : [DeviceAfterChangeSampleMode] Result:1
2019/11/02 09:58:10,237.402: 2019/11/02 09:58:10,237.393: T008e8: TL08: ASIOProxyProcess: Done : [Prepare] Result:-1 Wait:0
2019/11/02 09:58:10,237.495: 2019/11/02 09:58:10,237.488: T008e8: TL08: PrepareDevice result: OutOfSpec
2019/11/02 09:58:10,237.575: 2019/11/02 09:58:10,237.568: T008e8: TL08: Sample rate is out of spec.
2019/11/02 09:58:10,238.049: 2019/11/02 09:58:10,238.042: T008e8: TL08: Post PlayerNotify: 7006 [SpecUpdate]
2019/11/02 09:58:10,239.216: 2019/11/02 09:58:10,239.207: T008e8: TL08: Creating decoder for file [test.dsf]
2019/11/02 09:58:10,239.355: 2019/11/02 09:58:10,239.347: T008e8: TL08: Device does not support DSD, creating DSD-PCM decoder.
2019/11/02 09:58:10,239.560: 2019/11/02 09:58:10,239.549: T008e8: TL08: Opening file with RAMDecode:No : test.dsf
2019/11/02 09:58:10,243.873: 2019/11/02 09:58:10,243.872: T02d10: TL08: Proc PlayerNotify: 7006 [SpecUpdate]
2019/11/02 09:58:10,244.317: 2019/11/02 09:58:10,244.315: T008e8: TL08: Opening tune file to decode.
2019/11/02 09:58:10,244.454: 2019/11/02 09:58:10,244.453: T008e8: TL08: Block count 126513152 cause NO fraction in final DSF page.
2019/11/02 09:58:10,244.462: 2019/11/02 09:58:10,244.461: T008e8: TL08: at file: test.dsf
2019/11/02 09:58:10,245.160: 2019/11/02 09:58:10,245.159: T008e8: TL08: Decoding range is block:11 to block:31628299 - 1
2019/11/02 09:58:10,245.203: 2019/11/02 09:58:10,245.202: T008e8: TL08: Opened file: test.dsf
2019/11/02 09:58:10,245.209: 2019/11/02 09:58:10,245.208: T008e8: TL08: 1 Sample:32 bit, 1 Word:32 bit.
2019/11/02 09:58:10,245.588: 2019/11/02 09:58:10,245.587: T008e8: TL08: DSP: DSP array is disabled.
2019/11/02 09:58:10,245.709: 2019/11/02 09:58:10,245.708: T008e8: TL08: PLTTrace released(P): 01
2019/11/02 09:58:10,245.717: 2019/11/02 09:58:10,245.716: T008e8: TL08: PLTTrace assigned: 02
2019/11/02 09:58:10,249.727: 2019/11/02 09:58:10,249.725: T008e8: TL08: DSP: DSP array is disabled.
2019/11/02 09:58:10,249.808: 2019/11/02 09:58:10,249.807: T008e8: TL08: Stage: [PrepareDevice]
2019/11/02 09:58:10,249.934: 2019/11/02 09:58:10,249.932: T008e8: TL08: DSP: DSP array is disabled.
2019/11/02 09:58:10,249.980: 2019/11/02 09:58:10,249.979: T008e8: TL08: --- Preparing device for INT / 88200 Hz / 32 bit : [NU Audio]
2019/11/02 09:58:10,249.988: 2019/11/02 09:58:10,249.987: T008e8: TL08: Auto resampler: [If device does not support sample rate]
2019/11/02 09:58:10,250.020: 2019/11/02 09:58:10,250.019: T008e8: TL08: --- Try 1/8: Preparing device by [PCM] 88200 Hz.
2019/11/02 09:58:10,250.063: 2019/11/02 09:58:10,250.062: T008e8: TL08: ASIOProxyProcess: Call : [Confirm] Param:0
2019/11/02 09:58:10,250.209: 2019/11/02 09:58:10,250.208: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.146: T00edc: TL01: Error: Calling ASIO getChannels failed. Error -1000
2019/11/02 09:58:10,250.216: 2019/11/02 09:58:10,250.215: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.150: T00edc: TL01: Error: - Driver: [NU Audio]
2019/11/02 09:58:10,250.224: 2019/11/02 09:58:10,250.223: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.154: T00edc: TL01: Error: - Hardware input or output is not present or available.
2019/11/02 09:58:10,250.231: 2019/11/02 09:58:10,250.230: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.157: T00edc: TL01: Error: -
2019/11/02 09:58:10,250.238: 2019/11/02 09:58:10,250.237: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.183: T00edc: TL01: Error: Fail to ConfirmASIOSpec.
2019/11/02 09:58:10,250.247: 2019/11/02 09:58:10,250.245: T008e8: TL08: ASIOProxyProcess: Done : [Confirm] Result:0 Wait:0
2019/11/02 09:58:10,250.268: 2019/11/02 09:58:10,250.267: T008e8: TL08: Error: Quering ASIO driver spec is failed.
2019/11/02 09:58:10,250.279: 2019/11/02 09:58:10,250.278: T008e8: TL08: PrepareDevice result: DeviceFailure
2019/11/02 09:58:10,250.295: 2019/11/02 09:58:10,250.294: T008e8: TL08: Preparing device failed. Reinit device.
2019/11/02 09:58:10,250.311: 2019/11/02 09:58:10,250.309: T008e8: TL08: ASIOProxyProcess: Call : [Reinit] Param:0
2019/11/02 09:58:10,250.725: 2019/11/02 09:58:10,250.724: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.323: T00edc: TL01: Re-initialize ASIO Driver from Stage: [Initialized].
2019/11/02 09:58:10,250.770: 2019/11/02 09:58:10,250.769: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.329: T00edc: TL01: Calling ASIOCloseDriver_SEH_Wrapper.
2019/11/02 09:58:10,250.783: 2019/11/02 09:58:10,250.782: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.350: T00edc: TL01: Calling ASIOCloseDriver_SEH_Wrapper completed.
2019/11/02 09:58:10,250.791: 2019/11/02 09:58:10,250.790: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.353: T00edc: TL01: Driver stage: [Initialized] -> [None ]
2019/11/02 09:58:10,250.798: 2019/11/02 09:58:10,250.797: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.361: T00edc: TL01: Calling ASIODeleteDriverList_SEH_Wrapper.
2019/11/02 09:58:10,250.805: 2019/11/02 09:58:10,250.804: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.365: T00edc: TL01: Calling ASIODeleteDriverList_SEH_Wrapper completed.
2019/11/02 09:58:10,250.813: 2019/11/02 09:58:10,250.812: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.482: T00edc: TL01: Opening ASIO driver ID:0: NU Audio.
2019/11/02 09:58:10,250.820: 2019/11/02 09:58:10,250.819: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.489: T00edc: TL01: Calling ASIOOpenDriver_SEH_Wrapper.
2019/11/02 09:58:10,250.827: 2019/11/02 09:58:10,250.826: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.503: T00edc: TL01: Calling ASIOOpenDriver_SEH_Wrapper completed.
2019/11/02 09:58:10,250.834: 2019/11/02 09:58:10,250.833: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.506: T00edc: TL01: Driver stage: [None ] -> [Loaded ]
2019/11/02 09:58:10,250.842: 2019/11/02 09:58:10,250.841: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.510: T00edc: TL01: Calling ASIODriverInit_SEH_Wrapper.
2019/11/02 09:58:10,250.849: 2019/11/02 09:58:10,250.847: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.640: T00edc: TL01: Error: Calling ASIODriverInit_SEH_Wrapper failed. Error 1
2019/11/02 09:58:10,250.855: 2019/11/02 09:58:10,250.854: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.643: T00edc: TL01: Error: - Driver: [NU Audio]
2019/11/02 09:58:10,250.864: 2019/11/02 09:58:10,250.862: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.646: T00edc: TL01: Error: - Incorrect function.
2019/11/02 09:58:10,250.872: 2019/11/02 09:58:10,250.870: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.649: T00edc: TL01: Error: -
2019/11/02 09:58:10,250.880: 2019/11/02 09:58:10,250.878: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.661: T00edc: TL01: Error: Fail to initialize ASIO driver.
2019/11/02 09:58:10,250.886: 2019/11/02 09:58:10,250.885: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.669: T00edc: TL01: Calling ASIOCloseDriver_SEH_Wrapper.
2019/11/02 09:58:10,250.894: 2019/11/02 09:58:10,250.892: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.674: T00edc: TL01: Calling ASIOCloseDriver_SEH_Wrapper completed.
2019/11/02 09:58:10,250.901: 2019/11/02 09:58:10,250.900: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.677: T00edc: TL01: Driver stage: [Loaded ] -> [None ]
2019/11/02 09:58:10,250.908: 2019/11/02 09:58:10,250.907: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.685: T00edc: TL01: Calling ASIODeleteDriverList_SEH_Wrapper.
2019/11/02 09:58:10,250.915: 2019/11/02 09:58:10,250.914: T008e8: TL08: Prx: 2019/11/02 09:58:10,250.691: T00edc: TL01: Calling ASIODeleteDriverList_SEH_Wrapper completed.
2019/11/02 09:58:10,250.923: 2019/11/02 09:58:10,250.922: T008e8: TL08: ASIOProxyProcess: Done : [Reinit] Result:0 Wait:0
2019/11/02 09:58:10,250.940: 2019/11/02 09:58:10,250.938: T008e8: TL08: Error: Reinit device failed.
2019/11/02 09:58:10,251.005: 2019/11/02 09:58:10,251.004: T008e8: TL08: Post PlayerNotify: 7007 [SpecUpdate]
2019/11/02 09:58:10,252.457: 2019/11/02 09:58:10,252.455: T008e8: TL08: Error: Player device error.
post edited by TomSawyer2112 - 2019/11/02 10:47:27
