matt38002
One of my fans died on my original 3080 TI XC3 Ultra GPU. I just received the replacement and noticed a strange issue with the power limit. With the previous card I was able to set it to 105% and the power draw would be about 364 watts, this would result in slightly better performance all around. With the new one, increasing the power limit to 105% does nothing. The card seems to be hard limited to 350 watts even after adjusting the slider. Note that Precision X slider is working as I am able to decrease the power limit successfully. I looked into the detailed statistics in GPU-Z and for some reason one 8 PIN power connector draws max 120 watts, while the other draws 160 watts. I still have the old card on hand and can confirm that the load is even between the two power connectors at about 150 watts per connector. This is with the same NVIDIA driver and same version of PX. I have confirmed they are running the same BIOS version as well. What gives here? Does this fall under EVGA's QA? Is there a hardware issue or could there be some hard limit set by an EVGA engineer on this new card?
- Ribbons : 270
Re: Replacement 3080 TI XC3 Ultra Power Limit
2022/12/12 17:58:54
You could discuss this with EVGA and get their approval to swap just the fan or just the coolers between the two cards, so that you can keep your older better-performing card with the newer fan or newer heatsink/fan assembly. ...If you are up to that task.
matt38002
2022/12/12 18:07:38
I'd rather not mess around with the cards. I'm just more curious if this is within spec, or why it would be configured this way. So far it seems to be stable, runs cool. Just want to know where this hidden power limit is, as the monitoring software does pick up the bottleneck as "power limit".
- Ribbons : 270
2022/12/12 18:31:17
It's not an uncommon issue, and people will argue about the cause and whether it matters. If you do a benchmark with one and then do the same benchmark with the other, do you see a measurable performance difference?
post edited by ty_ger07 - 2022/12/12 18:32:34
matt38002
2022/12/13 13:40:06
Well from what I can cell from the benchmarks can range from 3-5 FPS less, however I feel the 1% lows in games may be more affected by this. After further troubleshooting, I ran a checksum on the BIOS ROM after taking a backup on the new card, against a copy of the SAME version from the techpowerup website, BIOS version is 94.02.71.80.C0. The MD5 checksum returned a different value, which leads me to believe there is a different configuration for this specific card that limits the PCI 8PIN #1 to draw a max of 120 watts only. I wonder if flashing the vBIOS with a clean ROM from techpowerup would change the power limits. However, I am concerned the original problem was "fixed" by EVGA by deliberately lowering the power limit on this re-certified/refurbished card. Quite interesting.
EVGATech_DanielM
EVGA Tech Support
2022/12/13 13:43:20
Can you please provide us screenshots of the main page of GPU Z for both cards?
matt38002
2022/12/13 15:41:49
EVGATech_DanielM Can you please provide us screenshots of the main page of GPU Z for both cards?
I didn't manage to grab a GPU-Z screenshot for the old card as I just sent it back today. However here are some precision x screenshots and power usage differences. As I mentioned perhaps the BIOS should be re-flashed on this replacement card? Old GPU functioned fine on the same system power limit wise. Images can be viewed in the drive link. Note the 8 PIN Power Usage on the power_limit_replacement_gpu screenshot. Again just for good measure I have switched around cables and ports on the PSU and it is always 8 PIN # 1 on the GPU that is stuck only drawing 120 Watts, this is where I believe the power limit issue resides on the vBIOS. The original card clearly was drawing 150 watts from each 8 PIN which is correct for the standard.
post edited by matt38002 - 2022/12/13 15:53:12
matt38002
2022/12/13 15:53:55
I can't seem to attach an image from imgur or even share a link to google drive. Does anyone have a quick explanation on how to do this?
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2022/12/13 15:56:29
Post your Imgur link broken up. I.Imgur .com/link. I’ll add it to your post for you.
You will be able to post images after you have posted a certain amount of time. It is a spam blocking feature.
matt38002
2022/12/13 16:01:53
the_Scarlet_one Post your Imgur link broken up. I.Imgur .com/link. I’ll add it to your post for you.
Thanks, these are the images. imgu r. com/a/HUsqksu
post edited by the_Scarlet_one - 2022/12/14 03:34:53
the_Scarlet_one
- Ribbons : 79
2022/12/14 03:35:17
Done, sorry for taking so long.
matt38002
2023/01/26 20:18:10
Just to update this thread, I RMA'd the replacement card, just got the 2nd replacement today. Power distribution is normal between both 8 PIN connectors averaging around 140-150 Watts. Board Power consistently stays 340-350 watts and if I raise the power limit in PX to 105% it hits 365 watts as expected. This was an unfortunate problem, I have read on forums this was quite prevalent on the FTW models with three 8 PIN connectors.
