Hot!Rebuilding water loops in my wall PC need vision and planning ideas.
Nazarus
2021/07/18 17:41:11 (permalink)
Essentially laid out like this cosmetically:
360 RAD > Reservoir > Motherboard > Void Space > Reservoir > 360 RAD
                    > PSU         > Video Card
Looking at turning my tube reservoirs into pump combo on each side (EKWB).  The pump has to be in the front because it will back to a flat surface.
[font="%value"]EK-Quantum Reflection Fractal ATX D5 PWM D-RGB - Plexi – EK Webshop (ekwb.com)
When I'm making this conversion, I get a little lost where exactly the best spots are to put the tubing.  Each side will only have an inlet/outlet for RAD and CPU/GPU respectively.  There is a total of 4 hook-in points.  Should I bundle them both up top or give them room to breathe between.  Fill in the dot kind of thoughts?  Fill and drain exist as separate locations.
    o   o
            o
  o   o
            o
            o
  o   o
    o
I'll be repeating the method on the GPU side.  Image in my signature is dark, but my modsrig link will give a few pictures in better lighting.
    o   o
            o
  o   o
            o
            o
  o   o
   o
Long-term vision idea here.  With the hybrid K|NGP|N I was forced to behead my water loop for the GPU while I wait on the hydro conversion to surface.
Associate's Key:  RQAORCJB8JNEFOB / Affiliate Code:  YTOQRPH9OK
18 Replies Related Threads
    • Ribbons : 111
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/18 19:57:20 (permalink)
    Moved to Cooling.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    notfordman
    • Ribbons : 25
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/19 20:29:00 (permalink)
    I have seen your mods rig. I am confident what you go with will more than likely look pretty nice. Your whole room is a dream man/people cave.
    Those distro-plates are really nice when you can incorporate them. Current set-up is the two reservoirs on each side isn't it? Looks like you have room for those distro's you are wanting to use. Lot's of tubing run options there.
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/19 21:09:00 (permalink)
    This is the plan so far. Just need the hydro kit for the kingpin. Then it’s down for a remodel!
    post edited by Nazarus - 2021/07/20 11:04:14
    rmorse27
    • Ribbons : 16
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/20 10:15:18 (permalink)
    I would like to make 1 small suggestion if thats okay, you should look into 180 degree pcie adapters that will clean up those cables for the grphics cards I have 2 of them with my 3070 and they hide the cables very well.
     Intel i7 10700k 32 GB Corsair Ram 3600MHZ-MSI Z490 Gaming Plus Board EVGA RTX 3080 ti FTW3 ULTRA - Inland Platinum 2 TB M.2 NVME Drive - EVGA 1000 Supernova G6 PWS-Thermaltake Open Air Case-EK Kinetic Pump/Res -360 Radiator & 240 Radiator- LG 32 Inch G-synch 2k Monitor.
     http://www.heatware.com/eval.php?id=66896
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/20 10:58:29 (permalink)
    Not a bad idea.  I had to special order several pieces for my P7 because of the way I laid it out.  I'd have to buy another riser, only problem I have is I don't know what I would put into it.  I moved my video cards to the bottom right hand corner of the case.
    post edited by Nazarus - 2021/07/20 11:03:01
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/24 03:54:04 (permalink)
    Have my distribution plates and radiators in place. Waiting on the fans. Going to start on tubing too the distribution plate today.
    post edited by Nazarus - 2021/07/24 16:28:45
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/24 16:43:32 (permalink)
    Got the monitor built in, cut out a path for my 24-pin cable.  Putting the sides back on tomorrow and going to get the pipes going and hopefully at least get the CPU side filled.  Waiting on my hydro copper conversion kit before I can 100% GPU side.
    Planning on looking at these V1 Tech LED panels before completely sealing the system up and hanging it up on the wall again.
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/27 19:29:32 (permalink)
    Latest. Waiting for hydro convert kit, finish gpu tubing, finish led case border, and rad fans.
    post edited by Nazarus - 2021/08/01 12:31:21
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/07/30 20:19:02 (permalink)
    Was supposed to be done or at least fueling my loop today. But no. Newegg wanted to send my box to Canada before it came to me in the US. Half of the stuff was taken out of the box.
    Latest pictures:
    post edited by Nazarus - 2021/08/01 12:32:13
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/01 12:36:14 (permalink)
    Opinions.
    I have Purple, Green, and Clear Cryotfuel from EKWB.  What should I put in these tubes?
    post edited by Nazarus - 2021/08/01 12:41:20
    stelladaurmond
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/10 17:56:54 (permalink)
    wow what a awesome computer.
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/10 19:50:41 (permalink)
    I’m dealing with kingpin issues right now. Only thing holding me up now. :-(
    • Ribbons : 119
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/10 20:38:32 (permalink)
    I like to use clear fluid, its not flashy - however it does not cause issues either
    Not sure where your hosting your photos, this Thread seems slow to load?
    Gave +1 on your Mods Rigs page
    RTX Project EVGA X99 FTWK 2xEVGA2080Ti EVGA1200P2  Nibbler EVGA X99 Classified 3-GPU Water cooled 1600P2 AIO Folding  X99 2x1080Ti FTW3 Hybrid, 1200P
    Thank You for Your Support      I'm a Volunteer Moderator on the EVGA Forums ... Not an EVGA employee
    notfordman
    • Ribbons : 25
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/11 11:29:26 (permalink)
    If you're running separate loops try purple in one, and maybe clear in the other. Kind of like intake/ exhaust. Or whatever your taste prefers. It has worked well so far. :)
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/18 14:21:34 (permalink)
    Here we are almost done.  Posts shared in 30xx series forums explain why I'm held up.  RMA on my graphics card.  Hope to have this computer back on the wall next week. This is the progress so far!
    post edited by Nazarus - 2021/08/18 14:34:33
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/20 21:17:52 (permalink)
    Wrapped everything up.  Cussed the entire time trying to put it back on the wall.  Had to set it on PVC pipes on my desk take a breather, then hoist it the rest of the way.
    notfordman
    • Ribbons : 25
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/26 21:08:29 (permalink)
    Looks great! You can see the tubing runs better now. You must be a plumber as a side hustle.. lol
    The Lan-Li fans, are they in both previous and rebuild, and what do you think of them?
    Nazarus
    Re: Rebuilding water loops in my wall PC need vision and planning ideas. 2021/08/27 17:05:58 (permalink)
    The fans themself are nice.  I think the controllers are garbage out of the box.  They seem to be acting better after I upgraded them.  Originally I couldn't get them to sync color with my motherboard, then I couldn't get them to let me adjust the RPM.  I prefer the border effects over the lit up fans.  Decent effects if you want something unique for your fans to do.  After I got through all the pains, they have been performing well.
    My PC doesn't like internal USB 2.0 hubs from the motherboard 2.0 internal ports.   About to split my USB 3.0 and step down one of the legs to a USB 2.0 and see if that performs any better.
