anupkumarrao@nc.rr.comMine sits between 23-27 degrees on idle. May also depend on ambient temperature as it is quite cold at the moment where I live.
benjamingreen22Greetings, I spent a good part of the day installing the hybrid kit for the 3080 FTW ultra. I had a few questions that seem to be giving me a problem. I am using the Rad on the front of my case, and I can't seem to tell how the fans are supposed to go. Usually, they have some sort of directions on how the flow and the spin of the fan go. My other question is that my GPU sits idle at 35-37 (celsius), is that optimal? When I start playing games it goes to around 50-60, I honestly don't think I have the fans set correctly. Any ideas? Thanks!
fugly16https://www.youtube.com/watch?v=VEjGUQhkCyA&t=137s&ab_channel=Fugly16 here are my temps playing warzone with a 3080 ftw3 hybrid card and a 5800x. Both AIOs are exhausting the heat out of my 5000D case.
kevinc313How are your fans set and what are they doing? The 3080 Hybrid should idle at 23C with the fans at 1000rpm in a 20c room, at idle power state. We have no idea if your gaming temps are good without knowing under load.
kevinc313What are the fan speeds at idle and load. What is the card power under load. What is the ambient room temp. Without this we can't tell if you just have a crummy setup or the mount of the kit is bad. With dual intake you are cooking the heck out of your ram and VRMs.
kevinc313You're not providing enough detail about your average power level (100% sustained? more?) and fan speed, but it's safe to say your setup or mount is crap. You are idling at the top power state, so low 30's is normal.
