Hot!RTX 3070 FTW3 ULTRA EK WATER BLOCK
rmorse27
  • Ribbons : 16
2021/05/08 12:48:28 (permalink)
Here is my updated rig with the RTX 3070 FTW3 Ultra and EK water block, I did have to battle a small air pocket but finally got it cleared, I replaced the led strip in the Vector FTW3 end cap with one that fits the lighting. The install was pretty straight forward happy with results.
post edited by rmorse27 - 2021/05/17 13:22:59
 Intel i7 10700k 32 GB Corsair Ram 3600MHZ-MSI Z490 Gaming Plus Board EVGA RTX 3080 ti FTW3 ULTRA - Inland Platinum 2 TB M.2 NVME Drive - EVGA 1000 Supernova G6 PWS-Thermaltake Open Air Case-EK Kinetic Pump/Res -360 Radiator & 240 Radiator- LG 32 Inch G-synch 2k Monitor.
 http://www.heatware.com/eval.php?id=66896
30 Replies Related Threads
    • Ribbons : 111
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/08 16:39:10 (permalink)
    Moved to Mods Rigs section.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    D3_GX
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/09 20:35:30 (permalink)
    It looks great, temps?
    supergamer86
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/20 18:19:34 (permalink)
    Nice like it how much $ you put into this project?
    Slippy103
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/28 16:43:52 (permalink)
    That water block looks sick.  I want to go vertical, but I have a H710 and I am on air...  no go unless I pony up for water.
    GOGUELLAE
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/29 15:34:13 (permalink)
    Is that the water block for the 3080?  I didn't know they made one for the 3070.
    rmorse27
    • Ribbons : 16
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/30 06:57:42 (permalink)
    straight from EK
    Ghost505
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/30 07:03:49 (permalink)
    How about the noise ? I had a watter block too but I found out that the noise was worse and you can achieve better temps with lower/no noise with proper silent fans.
    GOGUELLAE
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/05/30 08:31:42 (permalink)
    Thanks for the tip.  Nice set up!
    euzel42
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/01 15:03:23 (permalink)
    holy moly! i like the blue version. looks like its never gonna have overheating issues haha
    BebopFloyd
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/01 17:12:07 (permalink)
    That looks awesome!
    rmorse27
    • Ribbons : 16
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/02 07:36:29 (permalink)
    I recently picked up some pcie 180 degree adapters to help clean up those cables looks much better, will have pictures once mod rigs is fixed.
    COMeap GPU VGA PCIe 8 Pin 6 Turn 180 Degree Angle Connector Power Adapter Board | eBay
    euzel42
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/02 07:46:14 (permalink)
    whoa, cool build I'm always a fan of GPUs on risers.
    wppah
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/02 10:59:11 (permalink)
    the blue is just wooow
    ClutchAutomatic
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/02 11:01:01 (permalink)
    Neat those chassis take a lot of money to look good
    creed984
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/02 14:41:25 (permalink)
    I'm a big fan of the blue (like it more than red personally). Do you have any dust issues with that case or are the intakes filtered?
    sx0EVGA
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/02 15:51:04 (permalink)
    Solid product boss.
    cris78
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/03 12:50:41 (permalink)
    gorgeous!!!
    kroix007
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/10 02:11:53 (permalink)
    Wicked!
    R00thead
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/10 04:54:47 (permalink)
    IM BLUE DA DO DE DA DO DA DA DO DE DA DO DA
    GOGUELLAE
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/13 19:42:25 (permalink)
    OK, I keep sneaking back for a peek.!  I want that!!!
    rmorse27
    • Ribbons : 16
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/06/14 07:57:15 (permalink)
    right price and its yours.
    Blitzzwar
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/07/12 21:07:29 (permalink)
    That case definitely highlights your build.
    #23
    rmorse27
    • Ribbons : 16
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/07/13 07:45:12 (permalink)
    I have a small shop vac I use exhaust end to blow out the radiators every now and then plus rest of pc so dust isnt really a factor.
    #24
    Blitzzwar
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/07/13 13:23:06 (permalink)
    rmorse27
    I use this, I'll never go back to canned air :)
    https://www.amazon.com/Co...5vdExvZ0NsaWNrPXRydWU=
    #25
    notfordman
    • Ribbons : 25
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/07/14 13:48:58 (permalink)
    A very nicely done build. I like the case that shows everything off. +1 fer you.
    #26
    markedpk
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/07/24 14:40:55 (permalink)
    Simple yet pleasing
    #27
    • Ribbons : 75
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/08/10 02:14:35 (permalink)
    Added a comment into your mods rigs page.
    AMD Ryzen 9 5950X,  Corsair Mp600 Pro M.2 2TB, 128GB DDR4  Crosshair VIII Hero, Asus RX 6900 XT Associate Code: H5U80QBH6BH0AXF
    #28
    R00thead
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/08/13 04:36:36 (permalink)
    Very clean, love the light blue color you have going on.
    #29
    Lerpzu
    Re: RTX 3070 FTW3 ULTRA EK WATER BLOCK 2021/08/20 13:37:19 (permalink)
    Super clean build and love the color!
    #30
