RTX 2080 Hybrid : Swapping default fan for NZXT RGB one ?
ezork
2020/03/29 08:10:13 (permalink)
Hello,
I'm planning on buying the NZXT H710i case, and I would like to know if there was some way to change the default fan on the external radiator by an NZXT AER RGB fan, and still let the RTX control the speed of it, but make the H710i take care of the RGB stuff ?
I may have to do some cabling shenanigans, but I'm ok with it, juste wanted to know if it was possible at all :p
I hope I was clear with my request !
Thanks for you time and help,
Regards,
eZork
3 Replies Related Threads
    • Ribbons : 122
    Re: RTX 2080 Hybrid : Swapping default fan for NZXT RGB one ? 2020/03/29 09:25:13 (permalink)
    Yes, you can change fans on the Hybrid radiator
    Control of the RGB .... depends on Fan & control being used ... check with Mfg directions
    NOTE:  If your new fans are thinner than the stock fans .... use extra washers or Shorter screws .... do not puncture your radiator
    ezork
    Re: RTX 2080 Hybrid : Swapping default fan for NZXT RGB one ? 2020/03/30 06:24:19 (permalink)
    Hey Cool GTX,
    Thanks for your reply. What does " MFG" stand for btw ?
    I think that the NZXT FAN have 5 pins, 4 standards and I guess the last one for the RGB.
    So I think that would work with some cable work.
    I asked NZXT support to see if they have a solution.
    Will keep this thread updated in case anyone else need the informations.
    • Ribbons : 122
    Re: RTX 2080 Hybrid : Swapping default fan for NZXT RGB one ? 2020/03/30 09:42:35 (permalink)
    Mfg = manufacturer
    RGB & aRGB .... Currently have No Universal Standard ...
    You must know where the Ground pin is & what Voltage your parts use
