RTX 2060 KO strange revving noise from fans anything below 40%
Rhaze48
2020/05/26 22:31:17 (permalink)
Found my answer in another buried thread. Cheap fans, have to keep it at 35% at all times. :(
post edited by Rhaze48 - 2020/05/26 23:51:19
11 Replies Related Threads
    • Ribbons : 122
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/27 09:38:09 (permalink)
    Welcome to the EVGA Forums
    changing hysteresis from stock setting of 0 can also help stop a fan from revving -- try a value of 3 - 5
    This requires the set-point to be passed by the hysteresis Value before the fan changes to the next value
    Fan goes 60% @ 50 C -->hysteresis "5" then fan will not slow form 60% till 55C
    Ultimate Self-Starter Thread For New Members
    nick_b24
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/28 06:42:45 (permalink)
    Rhaze48
    Glad you found the other thread regarding this issue. Welcome to the club of bad EVGA engineering design choices
    For reference in case anyone else finds this thread instead of the other one, there is a problem with the chosen fans used on these graphics cards. When the fan controller of the GPU sends the fan a PWM value between 1-36%, the RPM of the fans themselves pulse up and down like an engine revving noise. This is because the fans are of bad design. Instead of the fans themselves rejecting PWM values of 1-36% and just stopping, they continue to try and spin at those values but they can't spin that slow so they pulsate. When the fan controller of the GPU finally sends a value of 0%, then the fans finally stop and make no noise. I suspect it is because EVGA was looking for a fan with this stop technology that they decided to choose these fans knowing full well that this is the downside of the choice.
    I've done a lot of investigation on this since it has been bothering me to no end. Also as an electrical engineer I felt like I at least had enough background to be able to understand what the root cause of the problem is to investigate it. The stock fans have a part number of PLA09215S12H. The S in the part number indicates this is a sleeve bearing fan. The same exact fan, but the bearing version with part number PLA09215B12H have been used for years by EVGA with no problem. I bought this old version online to try out. It is a 10 min job to change it on our graphics card and you don't even need to remove the heatsink (so no breaking the warranty sticker). All the screws are accessible from the top of the card (6 fan screws and 4 screws for the plastic shroud). After installing the PLA09215B12H version fan I bought I got to see a new behavior from the graphics card. Now the fans always spin at a minimum of 1142 RPM when the GPU is telling the card to spin at 0-36%. Therefore there is no more fan stop option. However, now there is no more revving up and down. When the GPU tells the card to spin at fan speeds under 36%, the fan knows it cannot spin slower and therefore stays at it's minimum RPM of 1142 RPM. When the GPU tells the fans to spin higher than 36%, then fans ramp up as normal.
    I know this work around might not be for everyone, but at least it gives some people out there the choice if they want. Unless EVGA releases a bios update that tells the fans to go to 0% directly after starting to ramp down and skip the whole 1-36% range, then there is no way to fix this. Unless you want to manually control the fans using software on the operating system level.
    Since February EVGA has acknowledged the problem to various people through support but till now they have not addressed the issue.
    Rhaze48
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/28 07:54:45 (permalink)
    Thanks, good information to know. It's insane to me that this got by QA, I've set a fan curve now of 0RPM up to 42 degrees and then a normal fan curve starting at 35% after 42 degrees.
    I think what is slightly more insane is that I watched about a dozen YouTube reviews of this card, and read just as many and not a SINGLE REVIEW mentioned this as an issue. It really would have modified my choices in purchase.
    Intel Core i9 9900K - Gigabyte Z390 Ultra MB - EVGA RTX 2060 KO - 32GB Corsair Vengeance LPX 3200 - Samsung EVO Plus 500GB NvME M.2 - Corsair RM650x PSU
    nick_b24
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/28 08:31:08 (permalink)
    Rhaze48
    I completely agree. The only really references I can find is if you go to reviews from Newegg for example and search for the word 'fan' and then you get some people complaining. The part that bothers me the most is how EVGA and others all suggest to simply use the Precision X1 software to fix this problem. I don't understand why I need to install and run a software primarily used to overclock my graphics card to simply stop my fans from destroying themselves slowly over time. I'm no fan expert, but I don't think that a fan that revs up and down constantly can be any good for the longevity of the fan components...but I guess it just needs to last long enough to work under warranty. I just want my card to work out of the box with the only thing running on my computer is the NVidia drivers.
    DeadlyMercury
    • Ribbons : 14
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/28 08:36:04 (permalink)
    Funny fact is that even 2080ti hybrid has same problem, but on pwm signal lower than 15% or 10%. But still instead of commanding 0% RPM - bios sending 9% rpm, 8% rpm and fan starts clicking.
    "An original idea. That can't be too hard. The library must be full of them."
    Stephen Fry
    GTXJackBauer
    • Ribbons : 48
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/28 21:27:37 (permalink)
    I think the whole design of making the GPU 'silent' backfired since the startup of these fans make noise and if they are voltage control instead of PWM, you can add motor noise as well.  I think it's best going back to the old way of cooling to keep things simple and not have noise complaints while the design was suppose to do the opposite.  If I didn't like the controls, I'd create my own custom fan curve.
    There are those that have no issues with the way the cooling is designed, probably because they have cooler enviroments where the fans aren't turning on while you have others in the middle trigger range (50c) that is start and stopping is driving people nuts.
    LMD3DNZM9LGK8GJ
    Pilsner73
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/28 21:56:24 (permalink)
    As I read this thread I just watched my 2060super card not go over 40c in the gpu-z monitor but yet the fans spun up a couple times, they went from 0rpm to very noticeable.  I bought the EVGA card because of the promise of fanless operation at normal card temps, when needed spin the fans up gradually to keep the card cool.  I have had a case open with support since early March where it seems they admitted a possible vbios issue but when I last inquired wanted to troubleshot ERP mode setting and what fan control software I am running (none).  I tried X1 but that didn't work out well for me.  I came from a 980 EVGA card that ran rock solid and did not have these issues so I am hoping EVGA can figure out a permanent fix but closing in on 3 months I'm not sure that will happen.
    freakdaddy64
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/29 03:33:40 (permalink)
    i just upgraded to
    msi b450 tomahawk max
    ryzen 5 3600
    16 gigs of gskill ripjawz 3200
    evga ko rtx 2060 ultra
    seagate firecuda hd 1tb
    thermaltake smart series 700 watt psu
    i dont hear anything but quiet quiet and quiet i love it system is smooth operator
    asus rog strix b550 f gaming ryzen 7 5800x3d cpu gskill trident z neo rgb ddr4 3600 ram sabrent 2tb ssd m.2 storage sabrent 1tb boot asus rog 4080 oc corsair 5000d case evga supernova 1000 t2 psu
    nzxt x73 rgb 360 cooler
    asus rog xg349c 34 inch display
    asus rog xg27aqm 27 inch 1440p 270 hz monitor THE SMOOTH OPERATOR
    Associate Code: YLOPU45V2M8FQL9
    Elite ID: 2RWCT4B87YQYR15NNQO
    DeadlyMercury
    • Ribbons : 14
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2020/05/29 04:03:16 (permalink)
    Set your gpu fans to 20% and you will understand what we are talking about :)
    Stephen Fry
    brad1138
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2022/09/10 10:55:53 (permalink)
    I just built a new computer for my kid, and I kept noticing the random noise...  I wasn't sure what it was till I spent 5 minutes with my head in the case, waiting for it to happen again. I then noticed it came from the new 2060KO... Which led me here.
    Any recommendation on good fan software. I have no problem telling it to stay above 1200 RPM all the time, as long as it stops the annoying rattling sound...
    brad1138
    Re: RTX 2060 KO strange revving noise from fans anything below 40% 2022/09/10 11:26:34 (permalink)
    OK, I found X1, works well and it looks like it's default fan curve keeps it above 40%. Must be their form of a "fix"...
