martinorta
Hi, I am having problems to put my memories with the xmp of the x299 dark and an i7-7800x in 4000 MHz. I get enabled xmp 1 in 4000 MHz but when I assign it and I save changes, the PC restarts, no image and remains the mother viewer in FF ... And I have to reset the bios . The model of my memories are F4-4000C19D-8GTZ and I have installed 2x4gb and 2x4gb. # BIOS 1.17 Capacity 8GB (4GBx2) Multi-Channel Kit Dual Channel Kit Tested Speed 4000MHz Tested Latency 19-21-21-41 Tested Voltage 1.35v Registered/Unbuffered Unbuffered Error Checking Non-ECC SPD Speed 2133MHz SPD Voltage 1.20v Fan lncluded No Height 44 mm / 1.73 inch Warranty Limited Lifetime Features Intel XMP 2.0 (Extreme Memory Profile) Ready Additional Notes Rated XMP frequency & stability depends on MB & CPU capabili
post edited by martinorta - 2019/04/30 21:03:16
bruno_ro
Re: Problems with gskill and xmp 1
2019/04/30 22:51:39
Try this: activate XMP, but manually change the frequency from 4000 to 3866 or 3600. If those don't work, try setting RAM manually. Start with 3600 with auto timings and escalate to 4000 if all good. Then you may change timings.
martinorta
2019/05/01 07:32:35
The support of evga told me that they were not compatible with the xmp, but in the qvl of the motherboard are the same version but 16gb ...
bruno_ro
2019/05/01 13:00:50
16GB are Samsung B-die and yours are not. Have you tried to set them manually?
2019/05/01 13:51:52
martinorta Additional Notes Rated XMP frequency & stability depends on MB & CPU capability
Yep. Sounds like your cpu imc can't handle 4000 MHz.
martinorta
martinorta
2019/05/01 16:08:51
A red LED is on and in FF the post screen
martinorta
2019/05/01 16:12:08
bruno_ro 16GB are Samsung B-die and yours are not. Have you tried to set them manually?
try manual mode, down to 3600 ... and it remains in another code as BL but without passing the post ... the microprocessor cooler is full but without image
bruno_ro
2019/05/01 23:31:11
Try manually 3200 16-18-18-36 @ 1.35V. And 3866 18-22-22-42 @ 1.35V. Maybe you get lucky. Most probably there is an incompatibility between that RAM and X299 Dark, so I suggest you buy a 4x 8GB Kit. Check the QVL of Dark and get one from there.
martinorta
2019/05/02 07:34:12
martinorta
2019/05/02 07:52:20
bruno_ro Try manually 3200 16-18-18-36 @ 1.35V. And 3866 18-22-22-42 @ 1.35V. Maybe you get lucky. Most probably there is an incompatibility between that RAM and X299 Dark, so I suggest you buy a 4x 8GB Kit. Check the QVL of Dark and get one from there.
to 3200 16-18-18-36 @ 1.35V. I start perfectly. I leave the features with aida64
martinorta
2019/05/02 07:53:21
I leave the features with aida64. It has samsung chip as well as the memories of qvl that comes in 2x8gb.
bruno_ro
2019/05/02 08:01:17
They may be Samsung, but not B-die. B-die is only on 8GB modules, not on 4GB modules. So you probably have E-die. You can use Typhoon Burner to find out exactly what chip you have. If 3200 16-18-18 runs, then try 3466, 3600, 3800 with the same timings.
bruno_ro
2019/05/02 08:16:24
FF means "A failure has occured" See more details at evga.com/support/faq/afmmain.aspx?faqid=59363
- Ribbons : 84
2019/05/02 10:43:35
A reminder to everyone that we can only accept posts in English.
martinorta
2019/05/05 10:17:21
Hello, I tried with another motherboard evga x299 dark since I own two units and it makes me the same error, I can not upload the memories to 4000 MHz. Therefore, discard the problem of which is the motherboard. My second evga dark has the bios 1.04 and the problem continues ...
