Kisameee
Hello everyone, I have problems with the EVGA GTX 980 ACX 2.0 Buy the card recently, it is d use but it is in perfect condition (at least apparently) and almost all games give me low FPS even lower than other cards I have had lower category. I've been looking for solutions on the internet for a while and until now I have not been able to correct it. I need help, what can I do? Best regards
Kisameee
Re: Problem with the EVGA GTX 980 ACX2.0. Low FPS in almost all games, especially DOTA 2
2018/09/11 17:21:13
In Dota 2 it does 50-70 fps, in ultra settings which is low for what this card should do. I have a friend who has a PC similar to mine but his card is a 1050 of 2GB and gives him +100 fps constantly. What can that be?
Dave3d
2018/09/11 17:28:46
Posting multiple times in different threads with the same problem is frowned upon here.
I7 9700k water cooled-32GB Ram-Zotac 2080 x2 SLI-Asrock Z390 SLI mobo-EVGA 1600W G2 psu-ABS Glass case-2560x1440 144hz IPS monitor-Windows 10 Home
Kisameee
2018/09/11 18:06:24
ok, I know from now on. You can help me???
joeymir
DavidO
2018/09/11 18:53:48
Hi to jump right in, is this an issue you have sense you owned the card or has it just happen recently? As mentioned system specs do help for a more detailed answer or response. If you do need assistance with this issue further could you respond to the PM I have sent or give us an email to Support@EVGA.com or call EVGA Customer Support Line 1 (888) 880-3842.
Dave3d
2018/09/11 20:34:26
Kisameee
Sorry, I had already posted in your other thread before this, so: https://forums.evga.com/FindPost/2855356 Check/replace thermal paste. Check with MSI Afterburner with 100% fan speed. Check in another PCI slot. Check with a different cable? And Sajin will be along to help you further. :)
Kisameee
2018/09/11 21:06:40
Forgive me, I should have put it earlier My PC is the following: Asrock Z97X Fatal1ty Killer I3 4160 3.6 ghz + Cooling Hyper 212 EVO 8 Gb RAM GSKILL 1866mhz Team Group Solid state drive 120 GB EVGA 600w 80 plus Certified Power Supply I play with a resolution of 1920x1080 .... In Dota 2 the fps oscillate between 30-80 fps with an average of 60 fps, in ultra settings without the vsync activated.
Previous to this card I had a GTX 1060 of 3 GB and I ran the game at 110 fps constantly, and it is not possible that the GTX 980 can not overcome that. There must be some problem.
Kisameee
2018/09/11 21:11:10
Oh, and I use Windows 10 pro 64 bits.
Temperature problem is not, because the video card I've never seen it go past 50 degrees, and the CPU is cold too.
I do not know if I'll try it on another PCI port, although I do not think that's the problem
2018/09/11 22:27:20
What are your gpu clocks running at while playing?
Dave3d
2018/09/12 10:20:11
Wow, you should have kept the 1060. The 900 series cards are bad. Everyone is having issues with them, except people who have them watercooled, or just got a good card. I would sell that and get another 1000 series card instead. Also, your I3 may be limiting the power of that 900. I am not sure how many pci-e lanes that cpu has, but it is pretty much bottom of the barrel cpu. Sorry.
Kisameee
2018/09/13 15:48:17
Yes, I should have stayed with the 1060, but look for many comparisons on the internet and all said that the GTX 980 was better than the 1060, but what I see is not like that.
EVGATech_DavidR
EVGA Tech Support
2018/09/13 16:06:53
I would recommend downloading 3DMark Basic Edition from https://benchmarks.ul.com/downloads/3dmark.zip and running the Firestrike benchmark, then after the benchmark, click the Compare Results Button and then copy and paste the URL here, so we can get a better idea of your system performance.
Kisameee
2018/09/13 16:17:27
Right now I was playing Dota 2 at 50 fps, that's impossible for this card. There is a problem there.
2018/09/13 16:35:34
You need to tell us at what speeds your gpu clocks are running at while playing.
Dr.Death
- Ribbons : 9
2018/09/14 09:48:45
need to post shots maybe like these to review running something ? maybe heaven for the results valley + gpu-z running at the same time irf still available in the free copy firestrik stress test a picture is worth a 1000 words as they say
joeymir
2018/09/14 16:41:32
Actually had tested at home months back an eVGA GTX 980 SC vs a Gigabyte 6GB 1060. Performance was extremely close, some games favored the 1060, while some(most) favored the 980. You wouldn't nor shouldn't notice a major difference. Like all others have said, run some benchmarks and use some monitoring software to see GPU utilization, Temps, and Frequencies. This will give us a good idea on what me be going on. And like someone else also pointed out. While the i3's are pretty stout given their price point, i can guarantee their is some bottlenecking going on there. You may try and pick up a i5 4690 or i7 4790 for some further performance gains. Have you tried downloading the latest Nvidia drivers and did a "clean" install during the driver install process? This can clear up some issues you may be having.
Gigabyte X570 Aorus Master | Ryzen 9 5900X | 32GB Crucial Ballisitx DDR4 3600MHz | MSI Radeon 6900 XT | Samsung 950 Pro 512GB | 2x Crucial MX500 1TB Raid-0 | 2x WD Velociraptors 500GB Raid-0 | Seasonic Focus Platinum 850W | Lian-Li PC-O11
Kisameee
2018/09/15 11:42:52
OK, im going to put some pictures, check them and please tell me if you see any problems.
Kisameee
2018/09/15 12:22:18
Give this a try... #1 Open the nvidia control panel and set your power management mode to prefer maximum performance. #2 Download/install precision xoc, and enable kboost. #3 Retest your games to see if your performance has improved or not.
Dave3d
2018/09/15 20:12:12
MSI Afterburner on 100% fan speed should get him through w/o hjaving to use kboost though. I wouldnt inst PXoc to save my life, it just crashes all the time and seems to mess up your graphics card also. :( Just my opinion.
Dr.Death
- Ribbons : 9
2018/09/16 07:37:16
I would of run like that fire strike bench to compare to it should tax the hardware [gpu/cpu] near fully cause that dota2 don't seem to gpu load only 11% and them gaps like seen in the perfcap and vddc ? I would think if a steady load on the gpu at any use that should be a solid bar not a -0- usage white line gaps in them ??? them white line gaps is like the card just stoped working all together
