mistapitts
So I've been playing around with it for a few days now, and I can't figure something out. Why on the section where I can adjust the fan curve does the option for "Enable Automatic Control" differ from the "Auto" under the fan speed section on the PCB overview section? For example, if I set a specific curve for the fan then I have to make sure "Enable Automatic Control" is checked. But whenever I adjust settings while on the PCB image with the "Fan Speed" section [not adjusting that] and hit apply, it turns off "Enable Automatic Control" despite "Auto" still being highlighted, and so card stops using my fan curve. I have to go back to the fan curve section, check "Enable Automatic Control" once more and reapply it. Is this how it is supposed to function?
post edited by mistapitts - 2018/11/13 04:42:38
Re: Problem understanding Precision X1 fan control settings
2018/11/13 11:48:55
So you're saying when you adjust other settings on the pcb page such as clock speeds the enable automatic fan control option gets unchecked? No, I don't think that is the way it's suppose to work at all.
mistapitts
2018/11/13 15:01:41
Sajin So you're saying when you adjust other settings on the pcb page such as clock speeds the enable automatic fan control option gets unchecked? No, I don't think that is the way it's suppose to work at all.
yep that's exactly right
d.burnette
- Ribbons : 17
2018/11/13 16:50:55
Perhaps the Fan Speed on the main screen is more for manually setting a set fan speed? Like if I want to just set mine to 100% for say a benchmark I want to run, I will just move the sliders over full and hit apply. So in essence it sets the fans at whatever I set them to , to run a constant speed at the setting I chose, so in effect negating the automatic fan control setting I had selected with my fan curve. I don't know obviously if that is the case and how designed, just speculating. Edit: Well I just re-read OP , think I had read it wrong as does not appear he was messing with the fan sliders.
post edited by d.burnette - 2018/11/13 16:54:01
Don EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
brahmzy
2018/11/14 05:28:15
I have wondered about this same exact behavior. Whole interface is extremely non-intuitive. Throw in all of the showstopping bugs and it’s a dumpster fire of a product.
mistapitts
2018/11/16 03:31:27
brahmzy I have wondered about this same exact behavior. Whole interface is extremely non-intuitive. Throw in all of the showstopping bugs and it’s a dumpster fire of a product.
Just updated to 0.3.6 and I think they fixed it, does it fix it for you too?
brahmzy
2018/11/16 04:12:23
Yes, 0.3.6 finally fixed some things. 0.3.7 is out and I’m apprehensive to try it as it, now that things are finally working...
2018/11/16 18:17:25
mistapitts
jernic
2020/02/08 10:17:57
V1.0.2 shows as latest as of 2/8/2020. I am also confused re "auto fan control" on/off and how that affects fan curve controls. Does auto off allow fan curve controls to set fans or not ? Also played with lock/unlock setting and that does not seem to affect anything. Then "auto off" seemed to allow fan curve controls to dominate for awhile but later it did not work. Setting curve control does not seem particularly sensitive toi GPU temps as I set it to 30 just to test fan speeds with "auto off" and got to 35 C with no fan action. What is maddening is it will work for a bit and then stop working. Seems awfully buggy to me. A simple declarative statement from EVGA on how these settings do, or do not, interact would be of great help.
SoM666
2021/01/20 19:24:23
i just got precision x1 and was stumped, but after closer squinting i saw the option. click on fan speed and look for fan curve control and enable the box
Gouramis
2021/05/03 19:33:04
I've been searching for the solution to automatic fan speed control for over a week, and, thank you for the solution. EVGA should make this selection box more prominent. Maybe make a tag that says "ON/OFF" or make the check box larger or maybe put a large arrow pointing at the box. Of course it's obvious when you know the answer.
