Problem routing EPS cables
ZoranC
  • Ribbons : 16
2020/01/20 19:20:23 (permalink)
I’m trying to route EPS cables in my build (X299 Dark + Corsair AX1600i in Cooler Master HAF X) and I am scratching my head how to do it cleanly without them just going across motherboard and video card. Is there something I’m failing to see or cables Corsair included are just too short? If later what would be solution? I can’t find Corsair offering longer EPS cables for this PSU and it is my understanding I can’yt get one from aftermarket either because original ones have integrated capacitors.
8 Replies Related Threads
    bob16314
    • Ribbons : 761
    Re: Problem routing EPS cables 2020/01/20 21:15:50 (permalink)
    There's extension cables like this one you can buy at most places PC parts/accessories are sold.
    ZoranC
    • Ribbons : 16
    Re: Problem routing EPS cables 2020/01/21 00:11:38 (permalink)
    bob16314
    I've heard they have worse performance than single longer cable so I am hoping for a single cable solution.
    wmmills
    • Ribbons : 40
    Re: Problem routing EPS cables 2020/01/21 08:21:32 (permalink)
    ZoranC
    bob16314
    None of these are compatible?! The bottom 2 say AX units and look like they have the cap in line too on them. Make sure though, ask Corsair if you cant figure it out for sure. They are very good with customer service. https://www.corsair.com/us/en/Categories/Products/Accessories-%7C-Parts/c/Cor_Products_Accessories_Parts?q=%3Afeatured%3AproductCategories%3ACor_Products_Accessories_Parts_PCComponents_PowerSupplies%3AaccessoryType%3AEPS12V%252FATX12V%2Bcable&text=&pageSize=12#rotatingText
    MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW
     New EVGA product? Register it NOW with this link:
    http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII
     Help Our Vets From K-2!
    [link=https://strongholdfreedom
    • Ribbons : 122
    Re: Problem routing EPS cables 2020/01/21 11:44:08 (permalink)
    I just went diagonal across the back & up around to the EPS on mine ... though different MB ... EPS were on top edge
    its a tight fit but should work
    ZoranC
    • Ribbons : 16
    Re: Problem routing EPS cables 2020/01/21 19:46:47 (permalink)
    wmmills
    ZoranC
    bob16314
    Longest Corsair's EPS replacement cables I was able to find are only 4" longer than what is included with AX1600i while I need at least 9", ideally 10". (... that's what she said)
    ZoranC
    • Ribbons : 16
    Re: Problem routing EPS cables 2020/01/21 19:50:57 (permalink)
    I considered it but inline capacitors on MB side make cable very stiff in that section, impossible to route in my case and further wasting inches :( It seems I have no choice but to get good quality extension while looking for perfect solution.
    knightsilver
    • Ribbons : 14
    Re: Problem routing EPS cables 2020/01/21 23:05:26 (permalink)
    link:
    https://modmymods.com/cables/8-pin-eps-cables.html
    Ya got pics of the case your trying to route ur EPS?
    fergusonll
    Re: Problem routing EPS cables 2020/01/25 22:41:37 (permalink)
    https://store.cablemod.com/configurator/
    You can check out cablemod, you can order individual/custom cables.
