Hello, please change it so that the VF Curve Tuner Scan actually applies my memory overclock during the scan, and not just uses 7000 no matter what. I actually know why it's probably set like that, as the default nvidia cuda profile is set to use power state p2 for any cuda tasks, which will cause memory to run 200mhz less, so it would say 6800 and to get around it they thought they would just force 7000 always. Well the real solution is to set in the nvidia profile to not use the p2 state for cuda, then it runs cuda without memory clock drop, which is what I did, and as expected, when I run test it is the correct setting, but scan still forces it down to 7000.
