CPU-1 Temperature refers to your processor's physical Core 1 (logical Core 0)..As you will see if your hover your mouse pointer over the lines in the graph area, there will be four lines, along with their temperatures, because you have a four core processor.
CPU Temperature refers to the processor temperature which is measured at the center of the IHS (Tcase)..Since there is no temperature sensor at the center of the IHS on Intel desktop processors (that I know of these days, you can get the white paper/Datasheet for your CPU at Intel from
here), this reading is usually either taken from the CPU socket temperature sensor of your motherboard or is guesstimated by the motherboard BIOS..This is also the CPU Temperature you will see in the BIOS.
Pay attention to the individual core temperatures (Tjunction) because they're what determines when core throttling occurs, that's what really matters..As I said, I haven't taken the time to review thermals from the Intel Datasheets for the new/newer processors but you can if you want to..I think your temps are looking fine, maybe a little bit higher than what I'd expect at idle though, I dunno..What are load temps when running
Intel Burn Test or the
Intel Processor Diagnostic Tool?
