Re: Power supply noob questions...
2021/06/16 20:24:24
I would also agree that getting a larger power supply that provides you enough headroom would be the wiser choice. 1000-1200 watt if possible would give a solid amount of room for growth. If you are running a SFX, then your options are extremely limited. But if you can swing a 1200 watt psu you should be good to go. 1000 will be fine as well if you can find them. Anything over 1000 watts is getting harder to find so if you come across one that fits your build and is in your price range i would buy it when you can.
Corsair 1000D Obsidian Case
I9 13900K with EK Velocity 2 Block
ASUS 4090 Strix with Optimus Block
ASUS Hero Z690 Mobo
64GB DDR5 RAM Trident 6000Mhz
1TB Nvme primary /2*2TB Nvme secondary/1tb & 2TB SSD drive
EVGA 1600 Watt PSU
30 Lian Li AL120 fans
2 * 480mm medium thickness rad, 2 * 360mm medium thickness rad, with
Two EK Pump/res combos. Custom hard tube loop.
Samsung G7 32" Monitor
EVGA Z20 Keyboard
Glorious Model O
